| Latest | 0 Rplys |
07-09-2016, 03:58 PM | #1 |
Badly broken coil and its stuck!!!
07-10-2016, 11:01 AM | #2 | ||
Re: Badly broken coil and its stuck!!!
As far as I can tell you need to pull/push the electrode inside the boot and then use the needle nose pliers to remove the rest.
Good luck and let us know what will happen.
The Following User Says Thank You to somick For This Useful Post: |
fantastic (07-10-2016)
07-10-2016, 07:53 PM | #3 | |
Well... It's out!!!
Talk about a battle!!! Pulled off the intake and then the valve cover to get a better look at the sleeve... Had a neighbour come over who is a mechanic or that would've happened!! Used some heat and was able to break apart the coil and get a lot out. The metal was completely corroded/rusted to the sleeve all the way down to the plug. I folded over a lot of the metal away from the sides and then put a screw through it all. Filled it with "Moovit" penetration oil and left it over night. Got a pair of vice grips on the screw and then pried it with a hammer and it pulled free... The rubber stayed attached to the plug but that only took a piece of hanger bent with a hook to get it out. Hope this helps someone in the future!! But I also hope no one ever has this issue!!! Here's a couple pictures... |
07-11-2016, 10:26 AM | #4 | ||
I am glad to hear that it worked!
Sam
