| Latest | 0 Rplys |
11-21-2016, 03:09 PM | #1 | |
2010 equinox abs codes c0035 and c0040
Hard to believe both right front and left front codes could be set- only takes one to light up the system abs light. But what I found out is that the driver had been driving for several months with abs light on- so in time, one side failed, then the other.. But here is the catch-- 2010 was first year for magnetic ring sensor detection mounted on rear of each front wheel hub- and what I found after I tore into it-(to clean corrosion out of notches I thought) was that the ring is brittle and had broken off in pieces- leaving only a small semi circle in place. So, once I replaced the left side- I was able to see that code stay away, and I could shine a light onto rear of right side and see that that ring was also incomplete and broken. The only fix is new wheel hubs ($118 at Autozone) that I know of- but this fixed the abs light, the red brake light, and the traction control light-as well as the abs activation at low speed-- now that the vehicle knows what speed the wheels are turning. Had to write this up, so others can know how easy it is to fix-- I had replaced the wheel sensors first- but that did not help obviously...
Automotive A/C Engineer with: '99 IH 4700 Toy Hauler (2) '95 GEO Prizms both maroon '99 GMC Yukon '95 Chev 3500, 454 Dually Crew Cab- 145k miles- Wife's Camel trailer puller. '94 Astro- 370k miles '94 Firebird Formula- 5.7L 180k miles- gone- '92 Chevy Lumina Van 3.8L 264k '86 GMC S-15 - 2.8L 154k '87 Buick Park Ave . 187k '86 Buick Park Ave 3.8L 199k miles- gone '77 Chevy Vega- 2.5L 175k miles gone but not forgotten '68 Camaro 396 4 spd RS/SS -72k miles- |
11-21-2016, 08:49 PM | #2 | |
Registered Offender
Re: 2010 equinox abs codes c0035 and c0040
Good information for future reference - Thanks for the report!
Permanent seat assignment on the Group W bench... Automotive Forums Survival Guide |
11-22-2016, 07:41 AM | #3 | |
I was surprised how easy they were to change- toughest part was to separate the hub from the mount- but a chisel and a 10 lb hammer made quick work of it.
I would have thought that if it happened on both front and right on this vehicle, that I would have seen a whole lot more on it when googling the codes- but perhaps it is still early in the failure mode (it is a 2010) and it was the first year for the glued on magnetic ring design. I spent about 2 hours internet time researching this and never read anything about the ring design-everything in prior model years is internal to wheel hub (has wire emitting from hub) so maybe this is "the tip of the ice burg." Just looked it up- same part number is used up to and through 2016 model year- so be on the look-out for more to fail in this manner- this might be big...
