Go Back   Automotive Forums .com Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 10-22-2014, 07:37 PM   #1
hdxjs
Ram 1500 heater fan quit
I started backing out of drive with a/c on and blower running fine. All of a sudden the blower just stopped. Checked fuse and it is good. What do I look at next?.
hdxjs is offline   Reply With Quote
Old 10-22-2014, 09:54 PM   #2
Chris Stewart
AF - Advisor
Chris Stewart's Avatar
Re: Ram 1500 heater fan quit
What year is your Dodge?
1992 Bravada, 201K, stock
1997 Bravada, 101K, stock...was "called away"
"Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14
Time to turn so's you don't burn.
Chris Stewart is offline   Reply With Quote
Old 10-23-2014, 09:33 AM   #3
hdxjs
2003 Ram 1500. I've read some post that say maybe ign switch?
Old 10-23-2014, 07:13 PM   #4
Chris Stewart
AF - Advisor
There are a few things that can cause your problem.
See if you can download this 2003 service manual then look at page 2801,
http://www.4shared.com/document/uUNW...ce_Manual.html
Old 10-24-2014, 07:37 AM   #5
hdxjs
I read on a post that tilting the wheel may help. I started truck, turned on fan, no fan, tilted wheel and fan came on. Not sure what that means, but kinda scary. Bad/loose wiring?
Old 10-24-2014, 09:09 AM   #6
aleekat
Post back, that's what makes Forums Work.
aleekat is offline   Reply With Quote
The Following User Says Thank You to aleekat For This Useful Post:
Chris Stewart (10-24-2014)
Old 10-25-2014, 04:30 AM   #7
hdxjs
Thumbs up Re: Ram 1500 heater fan quit
I looked at the YouTube video. Looks pretty simple to replace. I would never have suspected the ign switch, Thanks for all the help
