07-04-2007, 02:06 PM | #1 | |
trofeo sauna
I have a 92 trofeo, and I'll start the car then everything on thse panel goes blank except the tach. The defrost turns on automaticly and blows hot air. What can be done about this.
07-04-2007, 02:52 PM | #2 | |
A990 racer
Re: trofeo sauna
Welcome to AF. What panel, dash, heater control?
07-04-2007, 07:40 PM | #3 | |
Re: trofeo sauna
it's the instrument cluster, which is the digital odometer and the information center
07-05-2007, 05:27 AM | #4 | |
A990 racer
Re: trofeo sauna
It is more than likely failing.
07-05-2007, 08:12 AM | #5 | |
Re: trofeo sauna
yes I agree. But why? Any suggestions? I would like to fix it myself if possible
07-05-2007, 04:17 PM | #6 | |
A990 racer
Re: trofeo sauna
Can you overhaul a digital dash, take it out and apart , look for bad soldered connections, if you feel up to this, if not exchanges are available. Also check for proper grounds in the dash circuitry.
07-29-2007, 12:05 AM | #7 | |
Re: trofeo sauna
You're right. It IS the instrument cluster, and more specifically, a corrupt capacitor. The good news: cost a few cents to replace. The bad news: it is quite technical.
Here's a link that will tell you everything you need to know to fix it. http://webspace.netmatters.co.uk/cau...iv/ipc_fix.htm |
07-29-2007, 08:26 AM | #8 | |
Re: trofeo sauna
Thanks for the advice. I'm going to tackle it A.S.A.P the extra's about static control will be helpful. I'll let you know the outcome.
10-09-2007, 12:18 PM | #9 | |
Re: trofeo sauna
Hi there, the link you set up is not working can you help me to locate it? thx
10-09-2007, 12:21 PM | #10 | |
Re: trofeo sauna
could some one help me to find the instructions on how to replace the corroded circute in the cluster panel. the link does not go throgh. thx
