Car Modeling Share your passion for car modeling here! Includes sub-forum for "in progress" and "completed" vehicles. |
02-25-2010, 10:12 AM | #1 | |
glue problems
I'm trying to figure out which glues are best to use for modeling. I used to just use the Testors cement for plastic models (the real thick kind) Then I picked up the liquid Testors cement. But I've been having trouble with parts falling apart too easily (i.e. mirrors, windows, exhaust, etc...) So I found some Gorilla super glue. It bonds a little better but the problem is it expands which makes it difficult to hide. Also, When I'm using elmers white glue for the windows, they tend to come off pretty easily if accidently pressed too hard So I go back with the weak spots with the super glue. Same problem: it expands.
Would regular super glue work? any help would be appreciated. thanks |
02-25-2010, 02:52 PM | #2 | |
Re: glue problems
You will find that having a variety of glues and cements will provide the most flexible assembly options for you.
I use liquid cement for the body parts. It make for strong yet flexible joints. I use super glue for the mechanical parts like the engine, interior, and chassis. It dries fast and is easy to shape making the build process faster. I use special watch crystal glue for the clear parts. It dries strong, holds well with you first put a part on, and dries ultra clear. I use epoxy glue when applying metal parts to plastic, like photo-etch or white-metal. The glue is strong and flexible enough to hold together different materials. Hope this helps. |
02-25-2010, 03:59 PM | #3 | ||
Re: glue problems
When joining parts it also helps to have plastic to plastic contact. Best fuse possible. Not paint to paint. My arsenal consists of Super glue (crazy glue) I like the gel kind, don't need much. But fogs areas if too much is used. Testors white glue or even better glue is micro kritsal klear for windows and lights. White glue but dries clear. |
02-25-2010, 10:13 PM | #4 | |
Re: glue problems
thanks for the quick replies. I think my friend has some "clear window glue" (not sure the brand) maybe I'll Gank some of his as a test.
02-26-2010, 10:47 AM | #5 | |
Re: glue problems
Are you sure you're using Gorilla Super Glue with the blue cap?
Regular Gorilla Glue is not a super glue. It's notorious for expanding as it dries. CA glues (called super glues), including Gorilla Super Glue, don't expand when they dry. In fact, they contract a bit. Gorilla Super Glue is rubberized, which makes it less brittle and more flexible. So it's impact resistant, which I think is an advantage in model building.
D D M S |
Tags |
glue , gorilla , super |
