Go Back   Automotive Forums .com Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 01-01-2004, 05:32 PM   #1
jrwpmw
Dome Light & Radio Dead?
No it doesn't appear to be a fuse!
98 Dodge Ram 1500
The Glove Compartment Light broke loose and shorted out, the Radio and Dome lights also went out when this happened. No problem right... I just disconnected the Glove Compartment Light (never use it anyway). Then went to check fuses (in side and under the hood) - but they are all fine! I went over them a second time replacing them with new fuses just to be sure, but they look fine? Note, there were a few bigger fuses under the hood. I didn't check them becasue I didn't have a spare, but they seemed to be for bigger items (blower, etc).
Would anybody know what is going on?
jrwpmw is offline   Reply With Quote
Old 01-02-2004, 08:43 AM   #2
jrwpmw
Re: Dome Light & Radio Dead?
It turned out to be a 10AMP fuse (Labeled IOD I believe). It's one of those protected fuses with this black covers. I orginally didn't check that one or the air bag ones.
Old 08-12-2004, 05:03 PM   #3
JJFURAY
Iod 20a Fuse
I Also Came Across A 20a Fuse In The Engine Compartment That Has A Faulty Circuit. Can You Tell Me Or Anyone Out There What This Acronym Stands For?
Jeff
JJFURAY is offline   Reply With Quote
Old 08-12-2004, 07:51 PM   #4
JJFURAY
Iod Fuse
Ok! I Finally Figured Out What It Stands For. Just Not Sure What This Particular Circuit Does. Here Goes..... Ignition Off Draw. Any Takes For Ideas On This One?
Old 08-13-2004, 02:40 PM   #5
praisethelowered
praisethelowered's Avatar
Re: Iod Fuse
It probably covers those components that operate even with the key off (dome lights, headlights, cigarette lighter, etc.).
praisethelowered is offline   Reply With Quote
Old 10-23-2004, 03:24 AM   #6
RELENTLESSAPBT
RELENTLESSAPBT's Avatar
Funny My Glove Box Light Tried That Too. But Same Prob Occured When I Changed Bulb For Underhood Light
BUILD IT, BLOW IT, RETRY
3500 QUAD LARAMIE SLT 4X4 CUMMINS 5 SPEED 3.55 GEARS
328 HP @ 2580 RPM/ 782 FT LBS @ 1725 RPM@ WHEELS
7200 FEET ELEVATION
RELENTLESSAPBT is offline   Reply With Quote
Old 09-12-2011, 10:17 AM   #7
marinefa
Whoever posted this thank you, you just saved me 200$ that a repair shop was trying to charge me for a complete electrical system overhaul.
marinefa is offline   Reply With Quote
Old 09-12-2011, 06:24 PM   #8
Chris Stewart
AF - Advisor
Chris Stewart's Avatar
That's some excellent research on your part too....good work!
1992 Bravada, 201K, stock
1997 Bravada, 101K, stock...was "called away"
"Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14
Time to turn so's you don't burn.
Chris Stewart is offline   Reply With Quote
