Go Back   Automotive Forums .com Car Chat > Saturn > SC/SL/SW
Old 06-25-2017, 09:32 PM   #1
Jason1608
1995 Saturn sc2
My service engine soon light comes on and goes off several times during a hour long drive. I had the codes ran and got 0011.....0015....and 0055. I figured it had something to do with the transaxle so I changed the transaxle temp sensor but that didn't solve my problem because the service engine soon light still keeps coming on for a while and goes out for a while........any Idea's?
Jason1608 is offline   Reply With Quote
Old 06-26-2017, 06:18 AM   #2
Blue Bowtie
Registered Offender
Blue Bowtie's Avatar
Re: 1995 Saturn sc2
11 - Transmission general faults.
15 - Coolant temperature (CTS) signal below normal range.
55 - ECM fault.
It would be important to resolve the 55 error first, since that could contribute to the other codes being generated. Verify that the ECM connectors are clean and tight. It would be best to disconnect battery power first, then remove and insect the ECM connectors. While the ECM is disconnected, open the access cover and inspect the interior for moisture or corrosion.
