| Latest | 0 Rplys |
02-21-2014, 02:38 PM | #1 | |
1999 Rodeo V6 MT 3.2L Rear antifreeze leak
Started smelling antifreeze. Losing it towards the back of the engine, leaking onto the exhaust. Too hot to get underneath at the moment.
Heater core? Freeze plug? Head gasket? Other hose at the back of the engine? It's nothing at the front. Not the radiator or either hose like I hoped it would be. It's running fine. No noticeable compression loss. 273K miles. Will check water level when cooled a bit. Overflow still has antifreeze in it. All input welcomed. |
02-21-2014, 10:57 PM | #2 | |
Isuzu Guy
Re: 1999 Rodeo V6 MT 3.2L Rear antifreeze leak
see if the valley under the intake manifold is full of antifreeze (shine a flash light). There are a couple of anti-freeze tubes under it that like to leak (with +200k).
There are typically a couple of o-rings that need to be replaced: http://forum.planetisuzoo.com/viewto...freeze#p555560 http://forum.planetisuzoo.com/viewto...679&highlight=
-Ryan Isuzu Moderator Car Show Tips Operations manager with a results-driven passion for process improvement FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd |
02-21-2014, 11:20 PM | #3 | |
Thanks for the input Amigo-2k.
Couldn't see anything in those areas you mentioned. Poured a half gallon of antifreeze in and attempted to make it home (25 mi). Engine temp was normal til I hit heavy stop and go traffic. As soon as I saw the temp start to rise (12.5 mi), I pulled over right away. Called AAA and got it the rest of the way home. It had cooled by the time they arrived and I had filled the radiator again which took close to another 1/2 gallon. Since the remaining half of the journey home was heavy stop and go traffic the whole way, I stuck with having it towed (glad I have the premier level AAA) so as to not risk doing damage. Had local mechanic put it up on the lift and it appears that it's a freeze plug between the trans and the block. Work will commence in the morning. I'll post again once I know more. Sure glad it wasn't a head-gasket. Mark HB, Ca. |
02-22-2014, 12:28 PM | #4 | |
I haven't been able to locate any information in the official Isuzu Shop Manual concerning freeze plugs. Anyone know what Isuzu calls them?
I want to find them all. Last edited by dingobait; 02-22-2014 at 12:58 PM. Reason: added info |
