Old 11-18-2012, 12:26 AM   #316
WhiteRodeo4x4
WhiteRodeo4x4's Avatar
Re: How many miles do you have your Isuzu?
2001 Rodeo V-6 Auto. Just bought the car with 116018 miles. Frame was undercoated from day 1 so there ids no rust. Only problem I have so far is the #6 coil pack was on the wrong cylinder and was getting a P0300 code,and just found out that the front 4x4 actuator is either not working or the connectors are dirty. Car runs good and hasn't been beat to the ground. Original owner is from Vermont and traded car in at a Westboro Mass Dealership.
WhiteRodeo4x4 is offline   Reply With Quote
Old 12-02-2012, 05:24 PM   #317
dingobait
Year: 1999
Engine: 3.2L V6
Mileage:252,000
Any major problems: No
dingobait is offline   Reply With Quote
Old 02-17-2014, 06:56 PM   #318
M15TAK3N
1995
3.2
V6
111k
front rotors warped, rocker shafts and arms are ticking, routine maint other than that
M15TAK3N is offline   Reply With Quote
Old 04-24-2014, 11:39 AM   #319
kmoore74
Year: 2001
Engine: 2.2L 4-Cyl.
Mileage: 161,000
Any major problems: No, other than I can't seem to determine why it's recently began idling rough and I can smell gas/exhaust fumes when it's idling. I've replaced the fuel filter, fuel pressure regulator, plugs, wires, and I've ran Seafoam through the throttle body via vacuum hose, in through the gas tank.
kmoore74 is offline   Reply With Quote
Old 09-03-2014, 01:09 AM   #320
Miner2
Cool Re: How many miles do you have your Isuzu?
2000 rodeo 3.2 2wd 187000 miles
I have had this SUV for approx. 1 1/2 yrs.
Rebuilt tyranny, changed timing belt, TPS, fuel tank level sensor, shocks, and getting ready to replace seal on ac compressor. I like the power of this 3.2 and now the tranny shifts correctly. Nice car.
Miner2 is offline   Reply With Quote
Old 08-09-2015, 02:21 PM   #321
chritophur
93 amigo xs 2wd
2.6L, manual trans,
ac, sun roof, hard top, trailer hitch
325,000 miles
15"Michellins, aluminum rims =125k mi per set
I keep getting rear ended by women that "want to get to know me". Just wish they would realize I like my Isuzu more than any body, save me the hassle, and just give me money like all the other women.
chritophur is offline   Reply With Quote
Old 09-10-2015, 05:22 PM   #322
datphilthy1
Post Re: How many miles do you have your Isuzu?
Year: 1999
Engine: 3.2L V6
Mileage: 326207
Any major problems: None
I bought it reluctantly brand new with only 40 miles on it. I had just started a new job (which turned out to be my career), college and my son was 3 at the time. My dad told me I should get a more reliable vehicle and he picked it out and said he would help with the down payment if I got it. I hated it. Did not want a stick shift although I did want an SUV. So I bought it.
It turned out to be the best purchase of my life. Watched my son grow up from his car seat to the driver seat in Her, and She carried my second son home from the hospital when he was born in 06.
I kept Her up pretty faithfully with my oil changes and tune ups. I have to do a better job with flushing and replacing coolant and transmission fluids; I have done that at about 2x. But NO MAJOR PROBLEMS. Just got a new catalytic converter in 2013 costed me $600 just to pass smog. Other than that I did most of the work myself starter 2x, alternator once, fuel pump, and brakes once (just the front never had to do the back ones yet). Also had the AC compressor replaced a couple times, after this summer it may need it again.
I have used her as a commuter from Sacramento to the SF bay area for 6 years. She is still my commuter but now I only work 30 miles away from home.
Thought She was a goner a few days ago; all of a sudden She started smoking on my way to work and heard noise coming from the engine. I was sad. But turned out to be a broken Idler pulley. Got her back on the road the next day. She is still going strong, feels like I can get another 300k miles out of Her!
datphilthy1 is offline   Reply With Quote
Old 09-26-2015, 10:48 AM   #323
sdpassport
After a long hiatus after selling my 95 Passport I am back with a 1995 Isuzu Rodeo with 174K.
Interior is pretty clean but the engine leaks oil so I have some work to do.
"Bessie"
1995 Gray Rodeo
3.2L V6
174,000 miles
sdpassport is offline   Reply With Quote
Old 03-23-2021, 11:07 PM   #324
Sydkenmom
I was Googling how many miles a Rodeo can last and found this site. I have a 2003. Purchased used in 2008 with 67,000 on it. Currently has 159,000 miles. He's needed a bit of work over the years.
New radiator
New fuel pump
New water pump
New timing belt
Brakes replaced several times
Check engine light came on for the very first time last week. Tests showed decreased power. They are trying to replace something in the main computer system at my mechanic and having trouble finding someone to program it. Worried this could be the end. Some other problems I have:
Back will not stay up. You have to hold it up.
One door has not opened in about 8 years
ABS light is always on
CD player quit working in like 2009
2 different windows have broken and needed replacing
Key fob thing has not worked in over 10 years
I do love my car even with everything wrong. Hope they can get it fixed.
Sydkenmom is offline   Reply With Quote
Old 08-02-2021, 05:23 AM   #325
cherry97rodeo2WD
Hi Ramblin Fever, I am interested in how your Timing belt/water pump/tensioner (per maintenance rec. @ 59K) worked out, as may be considering similar on mine at 126800 miles, thank you!
cherry97rodeo2WD is offline   Reply With Quote
