11-11-2005, 10:11 AM | #1 | |
93 voyager crank sensor?
i have a 93 voyager 3.o it quit running all of a sudden!
it has no spark...new coil installed still no spark checked all the fusable links and fuses and also any relays i could find all are ok... does the 3.o have a crank sensor? and where is it located ...any help would be much appriciated..thanks |
11-11-2005, 10:32 AM | #2 | |
Re: 93 voyager crank sensor?
ill check back
11-11-2005, 10:34 AM | #3 | |
AF - Advisor
It is In the dist..
Have you got any codes? MT |
11-11-2005, 10:36 AM | #4 | ||
Re: Re: 93 voyager crank sensor?
im not sure how to retreive the codes on this vehicle it belongs to my sister im just trying to get it going for her
11-11-2005, 10:54 AM | #5 | |
i get a code 11 no power to ignition
11-11-2005, 11:20 AM | #6 | |
AF - Advisor
Code 11 is no crankshaft ref signal during cranking.
If your parts place can check dist have the test it. MT |
11-11-2005, 01:23 PM | #7 | |
ok i guess i need to start over here...are there any relays or fuses that may be hidden ...that operate the ign system????...i have installed a new coil and distributor today and still nothing!!
11-11-2005, 02:01 PM | #8 | |
AF - Advisor
Check for 8 volt power to crank sensor with key on.
Also remove dist cap and see it the dist rotor is turning. If your timming belt is broke the dist will not turn. MT |
11-11-2005, 03:50 PM | #9 | |
thanks for all your help it has a snapped timing belt..again thanks for everything
11-11-2005, 04:01 PM | #10 | |
AF - Advisor
You are welcome. I was afraid of that.
At least you found the problem. MT |
12-01-2005, 10:15 AM | #11 | ||
Toddluck....DO I know you from say ANOTHER forum? |
Thread Tools | |
