07-15-2014, 01:56 PM | #1 | |
How to tighten crankshaft pulley bolt
On a 96 ford escort 1.9 liter with automatic trans, after replacing the timing belt, how do you tighten the crankshaft pulley bolt when I only have hand tools? It needs 90 or 95 foot pounds but you can't tighten it because the crankshaft just turns around and I can't find a way to lock the crankshaft without causing possible damage to the pulley or putting stress on the new timing belt. I thought of taking out the starter motor and somehow blocking the flywheel but I don't want to cause any damage to the flywheel teeth. Is there a special tool or method to do this???????
07-15-2014, 04:39 PM | #2 | |
Re: How to tighten crankshaft pulley bolt
I have been using this method for years. "The Rope Trick". It's quicker and easier than the "tool", and the basic steps are simple:
(loosen/tighten)
1 - Pull plugs and rotate crank to #1 0° TDC Compression 2 - Rotate crank about 90° past TDC. 3 - Stuff about 3 feet of clothesline into # 1 plug hole, leaving 6" outside (feeding the rope in thru a short length of heater hose makes the job even quicker). 4 - Rotate the crank backwards until the packed rope stops further rotation. 5 - Use socket, breaker bar, and pipe extension to loosen pulley bolt. 6 - Tighten bolt the same way, but start with crank about 90° before #1 TDC Comp. 7 - Once tightened to spec, back the crank up a little and remove clothesline.
Post back, that's what makes Forums Work. |
07-16-2014, 04:06 AM | #3 | |
I would be afraid I couldn't get all that stuff out of the cylinder well after I tightened the bolt, think if that stuff got stuck in there, you would have to pull the head off to fix it.
07-16-2014, 05:21 AM | #4 | |
Oh that's really interesting! Whether is that possible to tighten crank pulley without dismantling the engine?
07-16-2014, 07:47 AM | #5 | |
Most ask the question- "how to loosen the cramk pulley" you must have used an impact wrench- so that is how I tighten...
Automotive A/C Engineer with: '99 IH 4700 Toy Hauler (2) '95 GEO Prizms both maroon '99 GMC Yukon '95 Chev 3500, 454 Dually Crew Cab- 145k miles- Wife's Camel trailer puller. '94 Astro- 370k miles '94 Firebird Formula- 5.7L 180k miles- gone- '92 Chevy Lumina Van 3.8L 264k '86 GMC S-15 - 2.8L 154k '87 Buick Park Ave . 187k '86 Buick Park Ave 3.8L 199k miles- gone '77 Chevy Vega- 2.5L 175k miles gone but not forgotten '68 Camaro 396 4 spd RS/SS -72k miles- |
07-16-2014, 09:03 AM | #6 | |
Been doing it for years. Dodges, Volvos, Mazdas etc. Everything from a big block V8 to little 1.8 2.0 4 bangers. Only issues I have ever heard of a guy forgot to pull the rope back out and cranked it over. Just make sure you are on TDC on the compression stroke so the valves are closed.
07-20-2014, 06:57 PM | #7 | |
I use to use the "rope trick" and it worked well for me. But I have recently tried the method where an old serpentine belt is back-folded around the crank pulley ... works pretty well, much better than I expected. Much quicker than the rope trick.
07-20-2014, 09:29 PM | #8 | |
Always willing to try something new. Care to elaborate?
07-30-2014, 12:39 PM | #9 | |
Let me find a link if I can ...
07-30-2014, 12:49 PM | #10 | |
