Go Back   Automotive Forums .com Car Chat > BMW > 3 Series
Old 06-07-2007, 02:19 PM   #1
01bmwsleuth
Question Fuel Sensor Problem
2001 BMW 325i. I've had an intermitent problem recently with my car running out of gas with the gauge showing about 1/4 tank of gas. It does not occur consistently. This occured yesterday, and I immediately filled the tank. It took 13 gallons, so the gauge was accurate, there were still 3+ gallons in the tank, but I "ran out" of gas. Any suggestions on solutions for this. Thanks in advance for your advice.
01bmwsleuth is offline   Reply With Quote
Old 07-12-2009, 12:04 PM   #2
john20santiago
Re: Fuel Sensor Problem
Check the resistance reading for the two fuel senders to ensure they are reading the same when the car is on the level. This will determine if one sender is faulty causing an inaccurate fuel reading. Near the bottom of the tank the reading should be about 10 to 20 ohms.
john20santiago is offline   Reply With Quote
Old 07-12-2009, 07:12 PM   #3
nathan19
This. Good luck OP
Ricer babyyy
nathan19 is offline   Reply With Quote
Old 08-12-2009, 02:51 PM   #4
samandy121
Change the engine oil. I think it is due to that only.
BMW E46 2008 BMW Parts Wheels
samandy121 is offline   Reply With Quote
