Go Back   Automotive Forums .com Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 09-22-2018, 09:58 PM   #1
imakedacookies
Not stopping after brake job
Just did just about everything brake related to my 2000 Dodge 2500 5.9 cummins auto transmission. Master cylinder is new and was bench bled. All the main rubber lines were replaced. Calipers pads rotors shoes and slaves were all replaced, I'm sure I'm forgetting something but it's pretty much 100% new. Had issues bleeding though. I got a little bit of air out all 4 lines but not nearly as much as I expected. The pedal is super spongy and can't stop the pickups power at idle in reverse and barely stops it in drive at idle. The only thing I can thing of is the calipers are full of air? I was reading that the bleed valve belongs in the top side and if it's on the bottom the calipers are upside down, but that's how they came off and I just put it together the same way it came off. Any suggestions would be awesome. Its parked on a friends lawn and it doesnt need to become a new ornament .
imakedacookies is offline   Reply With Quote
Old 10-14-2018, 08:36 PM   #2
imakedacookies
Re: Not stopping after brake job
Anyone that is interested, blead valves go on top. Dont be like me and put it back together the way it came off because the guy before knew what he was "doing" or you'll learn the hard way like I did.
The Following User Says Thank You to imakedacookies For This Useful Post:
Chris Stewart (10-15-2018)
Old 10-15-2018, 08:07 PM   #3
Chris Stewart
AF - Advisor
Chris Stewart's Avatar
Thanks for the update.
Have you checked your messages?
1992 Bravada, 201K, stock
1997 Bravada, 101K, stock...was "called away"
"Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14
Time to turn so's you don't burn.
Chris Stewart is offline   Reply With Quote
Old 10-30-2018, 05:49 PM   #4
imakedacookies
I just saw that. Thank you, I'll have to open it on my computer.
Tags
bleeding , brake , problems
