Go Back   Automotive Forums .com Car Chat > Subaru > General Discussion
Old 04-18-2005, 04:03 PM   #1
Vandals11
Subaru 1.8L EA82 Engine
I'm just curious as to a few things regarding these Engines.
1) What's the difference between the 1.8L EA82 and the 1.8L EA82T? Is the 1.8L EA82T just a turbo or what?
2) What year(s) and model(s) are these engines from?
Thanks.
Vandals11 is offline   Reply With Quote
Old 06-15-2005, 01:32 PM   #2
skibum1111
Send a message via AIM to skibum1111 Send a message via Yahoo to skibum1111
EA82 motors were introduced in 1985, they have dual timing belts and the distributor is on the back. I do believe that the T on the end was for the turbo's. They were used in all 85-89 except hatchback and brat, those used the EA81's, after that I'm not too sure...
skibum1111 is offline   Reply With Quote
The Following User Says Thank You to skibum1111 For This Useful Post:
BUANA (09-12-2011)
Old 06-28-2005, 09:35 AM   #3
Calebz
To add to the above, the EA82T (turbo) has different heads, intake and exhaust manifold than its NA cousins. The Turbo also has different pistons for lower compression.
The EA82 was available in turbo for up to 90 (Loyale) and SPFI form until 94
87 Subaru TurboWagon
01 Saab 9-5
05 Kia Spectra5
Calebz is offline   Reply With Quote
The Following User Says Thank You to Calebz For This Useful Post:
BUANA (09-12-2011)
Old 05-30-2007, 08:42 PM   #4
SubaruBratBoy
Re: Subaru 1.8L EA82 Engine
I recently became the proud owner of a 1986 subaru brat GL. I am interested in putting in an EA82 turbo, is it possible to put this engine in my car? It is a manual transmission.
SubaruBratBoy is offline   Reply With Quote
Old 06-01-2007, 02:31 PM   #5
somick
somick's Avatar
Visit www.ultimatesubaru.org
They have tons of information!!!
Sam
Originally Posted by RIP
Please post back when you fix it so we all will learn something
somick is offline   Reply With Quote
Old 06-01-2007, 04:33 PM   #6
SubaruBratBoy
Thanks for the website link. I do not currently have the vehicle i will be picking it up tomorrow. I know it has the EA81 and i want to add more power to it, i figured it might be easier to just put in a new engine. But i will definitely send some of my questions to the other webforum as well.
Danaan
Old 09-03-2011, 09:30 PM   #7
MilesFox
Send a message via ICQ to MilesFox Send a message via AIM to MilesFox Send a message via Yahoo to MilesFox
The EA82 was available from 85-94 in GL, DL, GL-10, RX, and XT
The xt versions are the same, except with flat belt pulleys. There are 3 variants, a carburetor with hitachi or carter-weber, with 8.5:1 compression ratio, and single port intake. There was also an SPFI (single point fuel injection) which shared the same head design, with the addition of a threaded egr port, and the block has a compression of 9.0:1. And yet, there were MPFI and MPFI turbo, both sharing the same block and heads, with the turbo version being 7.7:1 compression, and the n/a variant at 9.5:1 compression.
These engines can be swapped in place of an ea81, as far as the bellhousing and motor mount fitments. There will be clearance issues with the distributor and the brake master cylinder.
Swapping in a ea82t in place of an ea81 will require a modification to the engine crossmember to clear the turbo up-pipe. This is not an issue if you are replacing an ea81t. The same is true for replacing an ea82 with an ea8t.
Otherwise, the turbo engine crossmember can be fitted to a not turbo car to retrofit in a turbo engine of either ea81 or ea81.
I invented the TrashWagon.
83 GL wagon, originally yellow, ea81, 2wd 5wpd
now it has an ea82 motor, a 5spd dual range 4wd transmission, ea82 front suspension and rear isc brakes
sheetmetal body armor, and krylon paint job
shag carpet interior, and a stereo system mounted on the ceiling "roof of Boom"
milesfox@yahoo.com
come see http://usmb.ultimatesubaru.net
MilesFox is offline   Reply With Quote
Old 09-12-2012, 10:56 AM   #8
Elliottapp
Would be great if I can get some help in relation to this one.
I have purchased a Subaru 1.8L EA82 engine, currently fitted to a hovercraft as these engine were idea for certain craft. The engine has not come complete and I am in need of certain parts if anyone can point me in the right direction?
I am in need of an Alternator
Fixing brackets and bolts for the alternator
Fixing brackets and bolts for the accelerator cable
If anyone can help that would be great
Thanks
Elliott
Elliottapp is offline   Reply With Quote
Old 11-18-2014, 08:01 AM   #9
yella dog
anybody out there have a wiring dia. for a ea82. mainly the distributor and coil. does the coil require a external resister? I have a auto vom with a tach function, when I hook it up I get the rpm's go wild. any help out there? thanks john
yella dog is offline   Reply With Quote
