| Latest | 0 Rplys |
Car Audio Do you live in your car? Then you need to be able to listen to some high-quality music. |
09-28-2006, 11:54 AM | #1 | |
15" Kicker S15L7 D2
Brand:Kicker
Condition:New Impedance:2 Ohm RMS Power Handling:1000 Watts Peak Power Handling:2000 Watts Size :15 Inch Would this speaker match this amp? There is an 4 Ohm version of that kicker also. LANZAR 800 WATT RMS/1000w MAX CAR STEREO AMPLIFIER AMP
09-28-2006, 01:03 PM | #2 | |
Re: 15" Kicker S15L7 D2
lanzar is overrated, but if you went with that amp you would need the 4 ohm version of the kicker.
2001 Ford ZX-2 Alpine CDA-9855 SAX 100.4 Rainbow CMX 265 front stage Stock 5X7 rear fill Hifonics BX1505D TC-5200 |
09-28-2006, 01:10 PM | #3 | |
I vote no. the specs you put don't seem right and I would try to get a lot closer to that 1000 rms.
09-28-2006, 01:16 PM | #4 | ||
09-28-2006, 02:55 PM | #5 | |
The most that amp will push is 1000 watts Max. Your sub wants 1000 watts all the time and 2000 max. And he means the name is over rated.
09-28-2006, 03:13 PM | #6 | ||
09-28-2006, 03:17 PM | #7 | |
That sub needs like two of those amps.
96 EJ6. Future home of boosted B18C1. |
09-28-2006, 03:29 PM | #8 | |
So this picture should be your sub. Now I think in your specs it should say 1 channel with 1000 watts MAX should be 2 ohm. So if your speaker is indeed a dual 4 ohm and you wire it like the pic it will present a 2 ohm load to your amp. Which you will have 1000 watts MAX. It will work with your speaker but I don't recommend it.
09-28-2006, 03:35 PM | #9 | ||
09-28-2006, 03:55 PM | #10 | |
Do you already own this amp or are you looking for a new one? I used a jbl 600.1 gti which ran about 580rms. And I had a s12l5 which needed 600 rms. If you are looking for a new amp I would definetly not buy that one. I would look for something with 1000 rms or something closer.
09-28-2006, 04:08 PM | #11 | ||
With this amp would I need the 2ohm version? VISONIK V408XT 1000RMS 2 CHANNEL BRIDGEABLE CAR AMP
09-28-2006, 04:29 PM | #12 | |
How much are you looking to spend and what site are you at?
09-28-2006, 04:52 PM | #13 | ||
