Go Back   Automotive Forums .com Car Chat > Jeep > Wrangler
Old 07-30-2016, 07:08 PM   #1
ASJT3
Send a message via AIM to ASJT3
Rear brake issue - I'm stumped!
Hey guys,
'89 Wrangler YJ. I've been having a problem where under hard braking rear driver side wheel locks up and pulls hard left. I opened up the rear pass. drum and suspected wheel cylinder bad, so I replaced it. Issue not resolved. I then replaced both rear sets of brake shoes, including cleaning the drum backing and lubricating sliding surfaces. Issue still not resolved. I've bled the rear pass. drum line multiple times.
When I jack up the rear and apply the brake, the rear driver wheel is tight and cannot be rotated, however the rear pass. wheel can rotate by hand (albeit with some friction). I'm stumped!
I don't think there's any air in the line since have bled multiple times with clear liquid coming thru. I know the pads/drum combo works since applying the e-brake firmly sets both rear wheels. How to you explain this left-to-right braking variability? I"m almost wondering if the rear pass. wheel cylinder is defective, although I doubt since it was exhibiting exact same issue with previous wheel cylinder. Any thoughts? I haven't bled rear driver wheel cyl but didn't see need to since only replaced rear pass.
Thanks,
alex
2008 Tahoe SSV, 2007 Tahoe SSV, 94 GMC K1500, 93 Chev K1500, 91 GMC K1500, 2000 Wrangler Sport
ASJT3 is offline   Reply With Quote
Old 08-02-2016, 11:59 AM   #2
rhandwor
Re: Rear brake issue - I'm stumped!
Did you use a brake adjusting tool or screwdriver and adjust both sides so you have minor rubbing on both sides. As you didn't say I think one side is adjusted a lightly tight and the other side is loose. Also bleed both rear wheels you may have picked up air when changing the wheel cylinder.
rhandwor is offline   Reply With Quote
Old 08-30-2018, 06:27 PM   #3
spire-32
check portioning valve too
spire-32 is offline   Reply With Quote
