Engineering/Technical Ask technical questions about cars. Do you know how a car engine works? |
07-27-2010, 03:31 PM | #1 | |
Questions
Hey guys I just needed a couple questions answered so here I go
what triggers the ignition module? , Why do you bypass the ballast resistor when the engine is first cranked over? , What protects the ignition points from arching and whats the thing thats supposta act as an electrical shock absorber and last when you look at a spark plug can you tell the engine condition or no? It might be alot but just quick answers are fine. |
08-03-2010, 01:01 PM | #2 | |
The RustBuster
Re: Questions
What triggers the ignition module?
For older cars, it is usually the distributor. For newer cars it is the engine control module (ECM). Why do you bypass the ballast resistor when the engine is first cranked over? Probably because the engine alternator is not making enough current to augment the battery to help start the car when the starter is engaged. Bypassing the resistor allows full available power to the ignition coil. Once the engine is started, the alternator is producing more than enough current, making the resistor necessary to limit the current fed to recharge the battery at a safe level. What protects the ignition points from [arcing]? Don't know that answer, since I've never owned a car with a points-based ignition system. Breakerless distributors arc across the gap between the rotor and cap contacts (even though they don't actually touch). whats the thing thats [supposed to] act as an electrical shock absorber? In the distributor, I think you are referring to what's called the condenser (a small, barrel-shaped capacitor(?) connected to ground) to suppress arcing once the point contact is opened. When you look at a spark plug can you tell the engine condition or no? There are many sites that show photos of spark plugs in good and bad running conditions, such as this one. Basically: -Tan or brown with no deposits = Good -White ash deposits = Recent use of fuel additive -Golden or white glazed deposits or melted electrodes = Lean running conditions (not enough fuel) -Black soot deposits = Rich running conditions (too much fuel) or oil burning from worn piston rings/cylinders -Oily deposits = Leaking valve stem seals
Current Garage: 2009 Honda CR-V EX 2006 Mazda 3i 2004 Chevrolet Silverado 2500HD 2003 GMC Envoy XL 2000 Honda ST1100 2000 Pontiac Sunfire Vehicle History: 2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat. Last edited by jdmccright; 08-03-2010 at 01:44 PM. Reason: Added info |
08-05-2010, 03:31 PM | #3 | |
Re: Questions
Ahem, I know I'm showing my age here, but the condensor is what acts as an elecrical shock absorber to keep the points from arcing! Without it, the points won't last long.
