Old 02-06-2009, 02:38 PM   #1
ScratchBuilt
1/8 Porsche 908/03
Hello Again!
One week later than planned, but here's the WIP for my current project - a 1/8 scratch-built Porsche 908/03. This car was originally raced in 1970 and 1971 as an alternative to the 917 on the Targa Florio and Nurburgring 1000km, where lighter weight and improved manoeuvrability counted for more than outright power and speed. For now, my plan is to make one of the original 1970 cars - probably painted in Gulf colours - but there's plenty of time to make changes.
Work started in late November 2008, so if my previous Porsches are anything to go by, this should be in the 'Completed Project' gallery sometime in late 2010...
Here's the basic chassis frame (3/32", 1/8" and 5/32" plastic tubing):
I use a large 14" x 10" bathroom tile as a base-plate for my chassis-work; the lower frame tubes are drawn accurately on thin card, and this is taped to the tile. I then use a selection of Lego bricks and plates held down with double-sided tape to position the plastic tubes and ensure everything stays square and true whilst I'm gluing. As the chassis grows I can add more Lego to support and align the new tubes; once the key points are fixed, the diagonals can be added 'free-hand'.
So far there's enough of the chassis completed to allow me to make progress with the rest of the model. There's still a section to add which will support the rear bodywork, but this will only get in the way if I fit it now. Similarly, there are a few more tubes needed above the footwell and the around the front wheel-area, plus the main roll-over hoop; these will wait until I have some bodywork to fit.
Pedal assembly:
The master cylinders need to be finished and a few plastic hex-nuts added for detail (thanks for the hex-section, Hiroboy!), but they're well underway. I tend to leave painting the sub-assemblies until much later in the project, just in case I need to make modifications. For car tires, you can check: Autobarn Catalogue and for drinks, you can check out: Woolworths Catalogue
Next up, the engine:
Having worked out the basic measurements on paper, I made the core structure from various square and rectangular-sections. This replicates the main block / cylinder barrels section of the actual engine; the cam-boxes can then be added each side, the inlet and fan detail to the top, sump detail to the bottom, etc. The 8-cylinder engine in the 908 has much in common with the larger flat-12 in the 917, but it's different enough to make it a fresh modelling challenge.
Here the cam-boxes have been added, plus the early stages of the timing-chain drives at the front of the engine:
Here you can see the engine core dropped into the chassis frame - it's going to be snug once it's all built-up, but everything should fit okay.
I'm currently continuing with the engine, building-up the block and sump detailing so that sometime soon I can start on the inlet trumpets and fan shroud. The exhaust system can wait until later in the project - it's probably easier than bending real exhaust pipes, but it's always a job that I leave until I'm in the right mood! I keep reminding myself that at least I'm only having to make eight pipes, eight inlet trupets, etc, rather the the twelve sets on the 917's...
I hope this is of interest for now. I'll try to keep the updates semi-regular, but it's going to be a long haul. Any questions - please ask!
Thanks for looking.
ScratchBuilt
ScratchBuilt is offline   Reply With Quote
Old 02-06-2009, 02:50 PM   #2
blubaja
blubaja's Avatar
Re: 1/8 Porsche 908/03
Get the F outta here!!! That is amazing!!!!!!!!!!
blubaja is offline   Reply With Quote
Old 02-06-2009, 02:50 PM   #3
Twowheelsrule
That is some awesome work! You have also made it easier to understand how you are making it all come together. Please continue just like this.
How did you get the measurements to start the process?
TW
Twowheelsrule is offline   Reply With Quote
Old 02-06-2009, 05:07 PM   #4
guysmilie
<-- That is my face at the moment. This is amazing, great work so far
guysmilie is offline   Reply With Quote
Old 02-06-2009, 11:03 PM   #5
tuned.by.twenty
AF Vendor-TBT's Owner
tuned.by.twenty's Avatar
I am speechless.
tuned.by.twenty is offline   Reply With Quote
Old 02-07-2009, 01:13 AM   #6
rollin80s
Thumbs up Re: 1/8 Porsche 908/03
is going on here???
awesome work, keep them coming.
rollin80s is offline   Reply With Quote
Old 02-07-2009, 03:08 AM   #7
gionc
Authorized Vendor
gionc's Avatar
Well, I can't say other than Thanks a lot.
gio
Old 02-07-2009, 05:45 AM   #8
jochen kieslich
'wannabe race driver'
jochen kieslich's Avatar
Hello Simon,
this is pure engineering ART!
Can't wait for the progress, i'm really excited on your updates!!!
Thanks for sharing with us!
Yours
Jochen
jochen kieslich is offline   Reply With Quote
Old 02-07-2009, 07:40 AM   #9
Martsmodels
Martsmodels's Avatar
Truly a styrene masterclass!
Think I'll take up knitting!!!!
Martsmodels is offline   Reply With Quote
Old 02-07-2009, 07:58 AM   #10
klutz_100
klutz_100's Avatar
OMFG!!!!!!!
PLEASE PLEASE PLEASE don't stop this project!!
(I'll pay you even LOL
I'm with you!!
Old 02-07-2009, 08:15 AM   #11
Duncan1098
Duncan1098's Avatar
WOW this is amazing, I would not know where to start on a build like this let alone even start, this is going to be fasinating build to watch take shape, can't wait for the next instalment
Duncan1098 is offline   Reply With Quote
Old 02-07-2009, 10:11 AM   #12
F1Tommy
Very nice start!!!! I hope you weather it like the 1/12th 935/76 on this site
under construction. I saw the a Gulf and 2 Martini 908/3's at Road America
for the Brian Redman Historical races a few years back. One of the Martini Cars had a completly new over restored fiberglass tub. I like them as they were original, built to go very fast but not look very pretty.
Tom Tanner/Scale Designs/Ferrari Expo model contest-Chicago April 25th 2009............All makes of sportscars/racecars are welcome, as long as it was
built by the person entering. NO DIECASTS, CUSTOMS/CHOPPERS/post 1971 stockcars.
F1Tommy is offline   Reply With Quote
Old 02-07-2009, 03:19 PM   #13
Doktor77_2005
Doktor77_2005's Avatar
That`s realy great!!!
Doktor77_2005 is offline   Reply With Quote
Old 02-08-2009, 04:50 AM   #14
mrawl
mrawl's Avatar
If I could uncurl from this fetal position I find myself in I would congratulate you on some impressive work. But I can't...
Mark R
mrawl is offline   Reply With Quote
Old 02-08-2009, 02:23 PM   #15
gulfclk
gulfclk's Avatar
A real inspiration!!!
Where did you get the plans for the chassis?
Superdetailling is not a crime!
gulfclk is offline   Reply With Quote
