| Latest | 0 Rplys |
Corvette |
03-22-2005, 12:06 PM | #1 | |
2000 Corvett Ac Blows Cold On One Side Hot On The Other
Replaced Control Unit No Change The Ac Blows Vent Air On Drivers Side And Hot Or Cold On Passenger Side
03-26-2005, 03:49 AM | #2 | ||
Re: 2000 Corvett Ac Blows Cold On One Side Hot On The Other
09-03-2006, 05:23 PM | #3 | ||
Let me know if find out what the problem is because I am having the same thing happen to mine. Hot on the drivers side and cold on the passenger side. If I find out first I will let you know. |
09-04-2006, 10:58 PM | #4 | |
You'll have to get deeper into the system. The air flaps should be operated by electric servos. You need to locate that servo, operate the temp.control knob and look for movement at the servo.
The system uses air temp sensors to determine vent temp. You should have the body control system scanned and determine what the BCM is actually seeing. A misread vent temp would cause hot/cold problems. |
09-05-2006, 02:01 PM | #5 | |
i'm not familiar with the 2000 model, does it have dual zone climate control i presume?
10-14-2006, 09:55 PM | #6 | |
is most likely the temp actuator door for the respective side having the temp problem(since there are 2 of you with same problem but sifferent sides of car).
Disclaimer: I am not perfect, i may be wrong in my advice from time to time. Also note that any advice given is as is with no warranty whatsoever, and i have zero liability if you get hurt for not being safe while working on your vehicle. |
12-07-2008, 09:19 AM | #7 | |
if you don't care let me know what your problem was. I have a 99 doing just the opposite, thanks
