240Z | 260Z| 280Z | 300ZX (Past Z Cars) The original Z cars - ones that started it all. |
07-16-2006, 09:06 PM | #1 | |
Struts?
I thought I read somewhere that lots of wheel hop could be a result of worn out struts?
If this is a high chance of the problem: how much does a new set cost and is it hard to do alone with a jack and a toolset? THANKS GUYS! Sorry, I only realized this was the wrong section after I posted. I have a 1990 300zx if it helps. |
07-17-2006, 01:11 AM | #2 | |
Re: Struts?
1989 240SX Fastback. . . . . . . . . . . . . . . . . . . . . . . . . . . 1995 300ZX Twin Turbo Warning: Objects in mirror aren't as fast as they thought they were. |
07-17-2006, 01:11 AM | #3 | ||
Z Cars Fanatic
Re: Struts?
worn struts may contribute to the problem but not your biggest culprit. a full metric set of wrenches and sockets and maybe a breaker bar is the main things you will need for a strut change but you will also need a spring compressor. manual spring compressors can be purchased from a local parts store for pretty cheap. good luck. suspension can be a pain to work on.
ZedEx Crew Member #4 |
07-17-2006, 12:48 PM | #4 | |
Re: Struts?
and dont get a cheap manual strut compressor because they suck and the cheap ones tend to bend and break ....
Past Z Car Crew [The Enemy Of Your Enemy is Your Friend] >>Keep Your Friends close : But Keep Your Enemies Even Closer << |
07-17-2006, 03:04 PM | #5 | ||
Z Cars Fanatic
Re: Struts?
07-18-2006, 09:13 PM | #6 | ||
Re: Struts?
in my case I had to take a torch to the rear shock bolts becuase they were so damn rusted. good luck...
Georgey on the subject of midget beastiality pornos Quote:
R.I.P Andy, you will be missed by all. |
