Go Back   Automotive Forums .com Car Chat > Pontiac > GTO > Classic GTO's (1964-1974)
Old 08-12-2004, 11:58 PM   #1
Tempest1968
Camaro front end for disc brake conversion
I have a question. Can a third gen camaro front end fit under a 1968 Tempest. I just want the disc brakes. Any info would be of help.
Tempest1968 is offline   Reply With Quote
Old 02-12-2005, 10:03 PM   #2
hotrod_chevyz
hotrod_chevyz's Avatar
Re: Camaro front end for disc brake conversion
no you need to go with a secong gen cause its an actual complete subframe that bolts to the unibody where the third gen subframes are electric welded to the body.
hotrod_chevyz is offline   Reply With Quote
Old 02-14-2005, 12:25 PM   #3
MrPbody
AF -Advisor
The second gen stuff won't fit, either, without significant modification. The brakes from a '69-'72 A-body or GP, Rivvy and Monte Carlo will fit without modification.
MrPbody is offline   Reply With Quote
Old 02-16-2005, 04:20 PM   #4
hotrod_chevyz
i think he wants the sub frame pbody,ya know quick ratio steering like most people do.i have several for sale,78-79 sub frames complete.The most popular sub frames for upgrading cars with drum brakes is the mustang II and the second gen camero/firebirds.
Those 68 tempest steer like a barge,drum brakes suck,and if he goes ahead and subs it now,maybe he can get parts for it later when it needs a center link or lower A-frames.
Old 02-16-2005, 04:36 PM   #5
hotrod_chevyz
but for simplicity your right they did sell cars around the same year with disks but finding the parts and maintaining them for years becomes a costly pain in the hind quarters.
Old 02-17-2005, 08:50 AM   #6
MrPbody
AF -Advisor
I agree, grafting in a subframe from a '70-'77 T/A would be a good thing. Not trivial. Be sure to have a qualified frame shop line it up before welding it in. We did that to a '66 GTO a few years ago. Worked well. The WS-6 steering and brakes made that GTO act like a 2nd gen T/A.
Master Power makes a conversion "kit" for the A-body, to use the Delco-Morraine system. It's complete, and very good. About $900. Probably a bit less money in the long run. Ames Performance offers the WS-6 steering box in an A-body flavor, too. So I suppose, 6 of one, 1/2 dozen of the other...
Old 02-17-2005, 10:11 AM   #7
hotrod_chevyz
unless hes planning on doing a resto thats the way i would go but if you can get a whole new disk setup or system for less than 1,000 and keep the original frame,i might go for that.But it would have to come with the quick ratio steering tho.Im a sucker for how the camaros steer.That and the 79 monte carlos.I had a 79 monte carlo that steered better than my firebird.and it was on some mismatched junkie 14 inch steel wheels and maypop tires.
Old 11-02-2018, 11:23 AM   #8
theodora3DUsher
Did anything ever happen with this? Did you find the parts you were looking for?
Let me know if I can help, we 3D print classic car parts, from both plastic, composites, & (most) metals.
theodora3DUsher is offline   Reply With Quote
