Go Back   Automotive Forums .com Car Chat > Honda > Civic | CRX > '88 - '91 Civic | CRX | Wagon | Shuttlee
Old 06-21-2003, 09:34 AM   #1
91civichatch2571
91civichatch2571's Avatar
Send a message via AIM to 91civichatch2571
Axle Removal?
Which bolts do I take out so that I can pop the axles out of the tranny? All I have left to do do get the a6 out is that and the shift likage. Any helpful hints on either the linkage or the axles? Thanks.
91civichatch2571 is offline   Reply With Quote
Old 06-21-2003, 09:36 AM   #2
crxlvr
Slowest Automatic Civic
crxlvr's Avatar
Send a message via AIM to crxlvr
just bust the axle nut off with an impact gun, making sure to un crimp the tab thats notched first or it wont move, then just pull em out.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
crxlvr is offline   Reply With Quote
Old 06-21-2003, 09:40 AM   #3
91civichatch2571
Just the axle nut? Nothing Else? Thats easy.
Old 06-21-2003, 09:59 AM   #4
crxlvr
crxlvr's Avatar
you shouldnt have to take anything else off, you need to raise the car up off the front wheels tho, but just getting that nut off is a job in itself.
1991 Honda CRX
2003 Honda Accord
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 06-21-2003, 10:23 AM   #5
91civichatch2571
Do you know what size it is cuz I dont have any that big so I have to go to the store and get one right now.
Old 06-21-2003, 11:05 AM   #6
91civichatch2571
I found out that its 32mm if anyone else was wondering.
Old 06-21-2003, 11:58 AM   #7
91civicDXdude
91civicDXdude's Avatar
you'll have to remove the lower ball joint from the steering knuckle, so you can pivot the hub out to remove the axles, that is, unless of course your engine is out and you can pull the axles from the engine bay side..
91civicDXdude is offline   Reply With Quote
Old 06-21-2003, 12:36 PM   #8
H4Bangin
H4Bangin's Avatar
Send a message via AIM to H4Bangin
you do lowers?..i do the upppers
********** My 94 SS **********
90 civic dx 4 door d16z6 - p28, aem intake, act stage one clutch, cheap header- commuter car
H4Bangin is offline   Reply With Quote
Old 06-21-2003, 02:05 PM   #9
91civichatch2571
I got the lower ball joint off on the drivers side and it was pretty easy. I went over to the passenger side, got the nut off, but now it wont come off! Ive been pulling and prying but it doesnt budge. Im gonna find someone who has a gear puller and try that.
Old 06-21-2003, 02:15 PM   #10
H4Bangin
H4Bangin's Avatar
are u using a pickle fork?
Old 06-21-2003, 02:28 PM   #11
tbk49
tbk49's Avatar
Send a message via MSN to tbk49
the thing is hard to get off, I had to replace my axles, we used a hammer and one of those dent tools for metal work haha...it took us about 30 minutes of pounding to get it out
blah
tbk49 is offline   Reply With Quote
Old 06-22-2003, 12:40 AM   #12
91civichatch2571
no, i dont have a pickle fork but i went and bought a gear puller which i think will work perfect. I got one thats too big tho so ill try and return it tomorrow and get a smaller one.
Old 06-22-2003, 12:58 AM   #13
FourthGenHatch
FourthGenHatch's Avatar
Send a message via AIM to FourthGenHatch
http://www.fourthgenhatch.com
FOR SALE: Get this stuff out of my house!
-Stock hood (red) $30
-Stock Rear Spoiler (red) $30
-Stock mirrors $30/both
-Stock side front and rear side glass $30/piece
FourthGenHatch is offline   Reply With Quote
Old 06-22-2003, 02:40 AM   #14
civickiller
Send a message via AIM to civickiller
to get my axle in, i took of the strut and upper control arm, i dont like the lower ball joint because that will take all the grease out of it
Team Lonely Drivers
civickiller is offline   Reply With Quote
Old 06-22-2003, 03:14 AM   #15
Problem_Si
Send a message via AIM to Problem_Si
you really shouldnt have to take anything off to get it out. But it is a little easier if you take off the "wishbone" thing under the strut.
The axle nut is 32mm, and its a hell of a lot easier to get it off with the car on the ground. Then raise it up and finish taking them off. Use either a small pry bar or a wide screwdriver, and pop your axles from the differential. Should come right out with a few good shots.
Have fun....
There's nary an animal alive that can outrun a greased Scotsman!
Problem_Si is offline   Reply With Quote
Axle Removal? projectgsr Let's get Technical! 7 11-16-2004 11:29 PM
98 4x4 surburban front axle removal itourist Suburban 1 10-24-2004 08:12 PM
passenger side axle removal heimlevi Camry/Camry Hybrid/Vista 2 07-29-2004 09:47 PM
Axle removal Jos4DCivic '88 - '91 Civic | CRX | Wagon | Shuttlee 2 07-26-2004 05:08 AM
axle removal sl0d0wn '88 - '91 Civic | CRX | Wagon | Shuttlee 3 08-21-2002 01:03 AM
