Go Back   Automotive Forums .com Car Chat > Buick > Park Avenue
Old 08-14-2015, 03:56 PM   #1
jocro
display lights out
02 PA display lights for inside temp, fan speed, etc does not work...was fading out now completely out.......every thing functions just not displayed thanks for imput JOE
jocro is offline   Reply With Quote
Old 08-15-2015, 02:11 AM   #2
yekrats
Re: display lights out
I've got a similar (sort of) problem in our Toyota. In it, some of the led display lights for fan speed control, part of the dash lighting and a few other things doesn't come on immediately when you turn the lights on. Eventually they all come on at the same time. This indicates to me there is a bad connection someplace. Yours too probably. My guess for mine would be a break in the ground. (just a guess though) Now I could pull the panels, clean all the connections and see if that fixes it. (you never know though, it might also make it worse) That is, assuming I care to fool with it at all. Unfortunately, the problem could be anywhere. This is why repair shops most always replace everything. So, I guess what I'm saying is to consider carefully weather or not it's worth the risk. Everything still functions now. It may not anymore if you try to fix it. Sorry I haven't got an easy answer for you but it's just the way things are made these days.
yekrats is offline   Reply With Quote
Old 08-17-2015, 04:44 PM   #3
Cfrye66
I just had a similar problem with my 95 pa, it ended up being the control head itself, you can take it out, take two screws out and circuit board will slide out then check the solder joints.
Cfrye66 is offline   Reply With Quote
The Following User Says Thank You to Cfrye66 For This Useful Post:
jocro (08-18-2015)
Old 08-18-2015, 07:39 PM   #4
jocro
I guess I gotta take the whole dash out to get to it. Thanks fer your reply......JOE
Old 08-18-2015, 07:58 PM   #5
Cfrye66
It's really not as hard as you think, most of it just snaps off.
Old 08-18-2015, 08:36 PM   #6
brcidd
brcidd's Avatar
I've fixed those, by reheating the input solder joints-- and also by tapping on the control head with a wooden hammer handle- sometimes it will go 3 months on a hammer hit--- but then you need to go inside and reheat the solder joints.
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
brcidd is offline   Reply With Quote
Old 09-01-2015, 04:13 PM   #7
temperingloser
I have the same problem and have already bought a new unit on ebay for 50 bucks but I am going to try to repair the one I have first I will let you know
temperingloser is offline   Reply With Quote
Old 06-10-2016, 01:54 PM   #8
jocro
turned out to be easy....local radio guy soldered the resisters back together...20 bucks.. thanks to all....JOE
Old 07-12-2016, 12:28 PM   #9
Jroc0150
I have a 03 PA ultra, with the same problem on the climate control unit display. But it's also happening with the heads up display. So does this still sound like same problem u guys are having with the soldering?
If yes does anyone have a pic of the joints that need to be re-soldering?
Jroc0150 is offline   Reply With Quote
