Old 04-04-2001, 09:25 PM   #1
Dimex
What determines a redline? Am I just thinking about it too much and it's simply the maximum engine speed, or is there more to it? Just a thought.
Dimex is offline   Reply With Quote
Old 04-05-2001, 12:17 PM   #2
CraigFL
CraigFL's Avatar
The engineers that work at the car manufacturers generally take a lot of things into consideration in order to determine the redline. Things like:
Long term durability
Catastrophic failure (bending valves, breaking conn rods, etc.)
maximum accelerations of pistons, rods, etc
In the end, I'm sure everone on the design team agrees on a "safe" RPM that the engine can live at in the long term.
CraigFL is offline   Reply With Quote
Old 04-07-2001, 12:22 AM   #3
Dillweed
Yes, but...
That doesn't mean that an engine can take redline or let's say almost redline, all of the time.
You'll end up having head problems and probably crank bearing, or even crank itself, problems.
Some people are alive simply because it is illegal to kill them.
Dillweed is offline   Reply With Quote
Old 04-09-2001, 09:33 AM   #4
Bean Bandit
Bean Bandit's Avatar
Often the valves and bearings are the first parts that set a redline. But there come always new technologies e.g. some brands are working on introducing air controled valves(like F1) to regular cars that would raise the redline:bandit:
Bean Bandit is offline   Reply With Quote
Old 04-09-2001, 08:35 PM   #5
texan
Writer Mod
texan's Avatar
yep, Bean Bandit is dead on, it's almost always the valvetrain that limits maximum engine speed. Piston speeds and other factors can come into play later, but the old limits people imposed to fps (feet per second) piston speeds continue to be reliably surpassed as better metalurgy techniques become commonplace. For instance, the old hot rodders thought anything over 3000-4000 fps of piston movement was going to be disasterous, but production motors are pushing around 6000 fps now in some cases.
'03 Corvette Z06
'99 Prelude SH
texan is offline   Reply With Quote
Old 05-02-2001, 11:18 AM   #6
Steve
In turbine engines when a power turbine or gas producer turbine speed is exceeded mechanical inspections are required to determnine if the centrifical force has caused cracks in the turbine blade or caused a blade to contact the engine housing.
I've also seen rods thrown in 2 and 4 cycle engines caused from old exsessivly worn engines combined with high RPM. High RPM can also cause valves to float or not fully close, but I'n not much of an expert. Sounds like Texan knows alot about it.
Steve is offline   Reply With Quote
Old 06-18-2001, 04:03 PM   #7
death
Send a message via AIM to death Send a message via Yahoo to death
I think that the main readon is valve float, once you get to a certain point the springs on the valves cant close the valves quick enough, so that is one way the redline is determined. I was reading an article recently about a new valve technology, it uses spheres with slices cut out of them, when a whole part of the sphere is over the opening, the valve is closed, when part of the slice is over it, the valve is open. They tested this on a ford v8 from a lincoln that previously dynod at 240 hp after the new valve technology was installed, the engine made 576 hp and could easily rev to 17krpm. The power increase is from the lack of drag from the valvetrain, the rev limit is from the directnes of the valves, no springs to limit the rpms, i think that it was called radial sphere valve, but i could be wrong
"when a child asks why it rains a cute thing to say is 'god is crying' , when they ask why another cute things to say is 'probably something you did''
death is offline   Reply With Quote
Old 06-18-2001, 05:00 PM   #8
texan
Writer Mod
texan's Avatar
That's the Coates spherical rotary valvetrain you're speaking of death...
http://www.coatesengine.com/
'03 Corvette Z06
'99 Prelude SH
Old 08-17-2001, 07:26 PM   #9
olds88
olds88's Avatar
im not looking forward to the advent of electromecanial valve trains were insted of a cam opening and closeing the valves it is a eletrical sylonoid. and when the sylonoid eventuly wears oout and stickes in the oppen position WHAM instant bent valve. but it would be a great hp gain due to less engine effort being used to opperate the valve train.
what is the world coming to???
olds88 is offline   Reply With Quote
V-tec problems/engine bogs down before redline ldm376 Prelude 1 03-05-2010 01:50 PM
To redline or not to redline SexyCherb 3000GT/Stealth 6 09-15-2006 07:50 AM
Redlining with a Redline Gotian Street Racing 20 07-04-2006 02:11 AM
how much redlining is too much redlining? Dr GT Mustang Talk 8 08-26-2004 11:20 PM
GEORGE, anyone. What is the redline on P10's? NismoPC General 13 10-31-2001 02:34 PM
