Old 12-11-2014, 10:13 PM   #1
dyanz
stutters and bogs- help
I have been working on a 92 G20 van. 350 small block has tbi. Engine has 176K. Runs and sounds good during acceleration. But, at deceleration back to idle as it slows down to idle it stutters and bogs almost to a point that it dies but it continues to run. It will stutter. Apply the gas and it runs again and same results when decelerates. Seems to do it more when engine is at operating temp than when cold.
What we have done is change plugs, wire set, cap n rotor, new egr solonid, new 2 injectors for tbi. pcv valve, O2 sensor. Checked map sensor and egr valve working fine. Need suggestions.
dyanz is offline   Reply With Quote
Old 12-12-2014, 07:07 AM   #2
rhandwor
Re: stutters and bogs- help
Sometimes the throttle body needs cleaned.
http://www.rockauto.com/ sells a kit. Make sure you get one with a diaphram.
rhandwor is offline   Reply With Quote
Old 12-12-2014, 11:22 AM   #3
dyanz
I think that will be the next fix. I was also thinking that could it be the IAC?
Old 12-13-2014, 02:51 PM   #4
j cAT
just how did you test EGR ?? I doubt you did this with monitoring the intake vacuum .
EGR valves of this type work good for 10 years thats it.
Old 12-13-2014, 04:41 PM   #5
777stickman
Might also consider the ECT sensor.
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
777stickman is offline   Reply With Quote
Old 12-14-2014, 07:34 AM   #6
rhandwor
Be careful some aftermarket egr valves have washers and if you install the wrong washer they can cause this type of problem.
Old 12-16-2014, 11:48 AM   #7
dyanz
I think we are looking at the egr valve as the problem. We only looked at whether the diaphragm was able to be pressed closed with our fingers. We are now thinking that it doesn't close all the way letting air back into the system and causing the rich condition????? thanks
Old 12-16-2014, 05:00 PM   #8
j cAT
post back how it runs after to replace this egr.
