Go Back   Automotive Forums .com Car Chat > Chevrolet > Chevrolet Classics
Old 01-30-2017, 08:56 PM   #1
electro452
1989 c1500 stalls occationally under load
I have a 1989 c1500, 5.7 silverado with 390000 original miles. Lately I've been having problems with the vehicle stalling when I'm at a stop light, bwckung up, or pulling slowly into a parking space. I thought the IAC was going bad so I went a head and replaced it with tbe same results. The fuel pump is only about a year old and vacuum pump is a fww years old. It runs great cold and on the freeway justdies sometimes when it's nice and warm and idling under load..... any ideas on what might be the cause.?
electro452 is offline   Reply With Quote
Old 01-31-2017, 07:58 AM   #2
maxwedge
A990 racer
Re: 1989 c1500 stalls occationally under load
Sticking or carboned up egr is one possibility.
maxwedge is offline   Reply With Quote
Old 01-31-2017, 10:06 PM   #3
electro452
I took the egr off today and cleaned the carbon from the ports. I had an old egr that I took off the truck when I thought it was bad before. Anyway, there was no change , truck stalls when idling in gear .
Old 02-01-2017, 08:33 PM   #4
maxwedge
A990 racer
Is it idling so low that it dies? Stsrt right up?
Old 02-01-2017, 09:38 PM   #5
electro452
Idles fine then suddenly studders like it's fuel starved and dies. Starts right back up. I ordered a new delco IAC since the one I put in was a different brand and it acts like a IAC issue.
Old 02-01-2017, 09:39 PM   #6
kenman1717
this really sounds like module on the back of the distributor, really common problem. if the screws come out its a cheap fix, if they don't you may need a distributor. any parts store can get them, most even used to stock the module, as well as distributors for these truck, but not so much now with newer vehicles not having them.
2003 Chevrolet Silverado 4.8l w/4.56 gears
2002 Chevrolet Silverado 5.3l
2001 Chevrolet Silverado 6.0l eclb
kenman1717 is offline   Reply With Quote
The Following User Says Thank You to kenman1717 For This Useful Post:
electro452 (04-18-2017)
Old 02-01-2017, 10:11 PM   #7
electro452
You mean the ignition control module that mounts to the ditributor?
Old 02-02-2017, 01:40 PM   #8
kenman1717
yes that's exactly what I mean. they are so common on these for causing the exact driveability problems you are having. not always 100% the problem, blocking off the egr really helps a lot on these older ones too, but if you have emission testing in your area, might not want to block it off.
Old 04-18-2017, 02:29 PM   #9
electro452
Sorry I meant to follow up on this sooner......module was the culprit. I've had this go bad before but before the engine jus tstopped and wouldn't start...Thanks again all for the input...
Old 04-19-2017, 12:19 PM   #10
kenman1717
Glad you got it figured and that was all it was.
Old 06-01-2017, 02:34 PM   #11
Ol'Jim
Thanks to the original poster for coming back and updating the status, I wish more folks would do this, it really helps out others down the road who may run into similar problems.
-Jim
2015 Silverado Crew Cab 2500HD 6.6 Duramax 4x4
2002 Silverado Crewcab HD 2500 6.0 4x4 Sold 281K Great Truck
1970 Chevelle SS454 (Gave to my son 9 years ago for his 18th birthday. Yeah, I know, crazy, right? Thank goodness he doesn't drive it the way I would, -er, did...).
1971 Monte Carlo SS454 Drag Racer. The old girl finally got new paint!
1968 Camaro SS (New race car project). Caged, Tubbed, Back-Half/Ladder Bars. Rolling Chassis (For now).
Ol'Jim is offline   Reply With Quote
