Go Back   Automotive Forums .com Car Chat > Racing > Street Racing
Closed Thread Show Printable Version Show Printable Version | Email this Page Email this Page | Subscription Subscribe to this Thread
Thread Tools Search this Thread
Old 08-25-2003, 12:27 PM   #31
carrrnuttt
carrrnuttt's Avatar
Re: Re: carrrnuttt vs. 90redgt
Originally Posted by RedNeck383
again... i'd like to know how you made up the 2 second gap.
filter and exhaust isn't going to do much for your car in general, it'll help but its not going to give you the boost in power for the mid 15's like you estimate.
Stock Quad Cam V6 made like 190hp. And the '93 Z24 coupe only could pull in a 18 second 1/4. Filter and exhaust probably only gave you maybe 10hp at max.
See where i'm going with this?
Don't mean to correct you Matt, but his V6 was rated at 140HP. The QUAD4 motor is the one that's rated at about 180-190HP. Meaning: his car was still slower than my Beretta that DID run mid-15's.
2002_Nissan_Maxima_6-speed
carrrnuttt is offline
Old 08-25-2003, 11:08 PM   #32
-The Stig-
On Fire!
-The Stig-'s Avatar
Send a message via AIM to -The Stig-
Re: Re: Re: carrrnuttt vs. 90redgt
My bad.
2003 Chevy 1500HD - Hauler
1971 Chevy Camaro RS - Track Car
User Guidelines It's important to read, like the Bible. But unlike the Bible we will strike you down if you jerk off around here.
-The Stig- is offline
Old 08-26-2003, 02:09 AM   #33
Tinytim12333
look at my car it aint new or anyting
Rice Killer n Sleeper!!!!!!
Tinytim12333 is offline
Old 08-26-2003, 08:44 PM   #34
fatninja19
Send a message via AIM to fatninja19
Uh... is that statement leading to any valid point?
when in doubt, throttle.
fatninja19 is offline
Old 08-27-2003, 02:03 PM   #35
RACER D12
RACER D12's Avatar
Send a message via AIM to RACER D12
Do you have a SR20DE
Why yes, yes it would.
So then why do you want to swap in a SR20DET when you could just add a turbo to your motor?
Lindsey Boost Enhancer, Blitz EBC, Hot Air Intake, Koni Yellows
RACER D12 is offline
Old 08-27-2003, 02:56 PM   #36
carrrnuttt
carrrnuttt's Avatar
Re: Do you have a SR20DE
Although the crank/rods are the same as an already-turbo'ed SR20DET, and it can and WILL hold good boost and power, there are just too many things that are different.
Parts are interchangeable, but just buying the parts and replacing the stock parts will cost more than just outright buying a used motor, at least for me, since I have access to the best FWD SR20DET, the GTi-R version, for cheaper than most.
Here are the differences between the DET and the DE:
The DET has oil squirter piston coolers
The DET has a bigger oil pump.
The DET has a different front pulley.
The DET has lower compression pistons (8.3:1 vs 9.5:1).
The DET has bigger injectors.
The DET has direct ignition.
The DET has a variable intake cam, runs retarded at idle, advanced mid range and retarded top end.
The DET has mechanical shim in bucket type lifters with a slightly bigger in duration exhaust cam.
The GTi-R version has these advantages over the SR20DE and lesser SR20DET's
The GTi-R DET has individual Throttle body injection.
The GTi-R DET has stronger main cap bolts.
The GTi-R DET has beefier rods.
The GTi-R DET also comes with a t28 turbo stock, with bigger IC, compared to a smaller IC and t25 for lesser DET's.
For good reliable power, the stock SR20DE is recommended up to 250WHP before you'd have to beef it up a bit, but they recommend you keep the stock rods, which are already strong, if not stronger than some aftermarket rods. That is until you get to the levels below:
  • up to 400whp for a BB DET
  • up to 500whp for a GTi-R DET
BTW, I might be getting a turbo on my stock motor before I can get my SR20DET. My friend's shop is considering getting into making turbo kits, that he puts together himself, using refurbished JDM turbos (cheaper). He said that he might want to use my car as a mule to practice his manifold-fabrication skills. So, if he does, I get a free turbo-kit and install.
Old 08-27-2003, 03:22 PM   #37
RACER D12
RACER D12's Avatar
Ok I see Would the SR20DET fit in a 240Z or 280Z
Old 08-27-2003, 04:15 PM   #38
carrrnuttt
carrrnuttt's Avatar
Well, anything can fit into anything, given enough money.
You'll need the RWD Silvia SR20DET's for the Datsun's RWD application. You might even be able to fit a an RB (Skyline) motor in there, considering they can be made to fit in the 240SXs.
The 240SX forum guys should be able to help you better.
Old 08-28-2003, 01:54 PM   #39
barrchr
this just doesnt add up. I run high 13s at 99 how can you pull a 15 flat at 99. the mustang MUST have been an auto and MUST have been a POS. Sure it looks nice but to lose to you, a POS. 15 flat sounds about right for the mustang but the nissan maybe 17.50s in good weather . With only bumped timing and an air filter, come on be for real.
bring what you brought and
hope you brought enough
barrchr is offline
Old 08-28-2003, 03:40 PM   #40
RACER D12
RACER D12's Avatar
Do some research before you open your mouth. Do you know anything about his car, hell you even have a car?
Old 08-28-2003, 03:56 PM   #41
RACER D12
RACER D12's Avatar
One more thing
Old 08-28-2003, 07:04 PM   #42
carrrnuttt
carrrnuttt's Avatar
Two questions: How many Classic Sentra SE-Rs have you driven? How many have you actually seen run?
Keep in mind, just because you've seen a random Sentra driven by your local "mobility enhanced domicile"-resident living in Tennessee and all, put-putting along, doesn't mean anything.
Old 08-28-2003, 07:27 PM   #43
-The Stig-
On Fire!
-The Stig-'s Avatar
'92 Sentra SE-R's run low 15's stock.
Shocking isn't it?
Old 08-28-2003, 09:11 PM   #44
-Josh-
Automotive love doctor
-Josh-'s Avatar
Send a message via AIM to -Josh-
OMG, what a jackass!!! The ignorance of some people!
Self improvement is masturbation
AF User Guidelines
What is a mippie? - click
-Josh- is offline
Old 08-28-2003, 09:20 PM   #45
jon@af
The Media Guy
jon@af's Avatar
Send a message via AIM to jon@af
j00 suXXX0r at teh thinking
AF User Guidelines <----Click and read if you don't know these.
"Dream as if you'll live forever. Live as if you'll die today."
A Blog By Swigz
Cotidie damnatur qui semper timet; Aquila non captat muscas.
jon@af is offline
Bulldog71SS vs. 90redgt 90redgt Street Racing 13 08-15-2005 11:17 PM
Carrrnuttt might be happy after hearing this.... EC0T3C Street Racing 18 03-01-2004 08:36 PM
90redgt RACER D12 COMPLETELY off-topic 7 02-18-2004 10:26 AM
carrrnuttt VS EC0T3C carrrnuttt Street Racing 42 12-06-2003 04:24 AM
Closed Thread
Bookmarks
Search this Thread:
