Old 09-18-2012, 10:08 PM   #1
tomhrhr
2001 Rodeo fuel leak?
I have a 2001 4x4 Rodeo that has leaked fuel twice after sitting for over a week. It seems to leak from the fuel line above the fuel filter, but only leaks if I don’t drive it for a week….I can’t tell where the leak comes from…just above the fuel filter under the drive side door… the leak stops after a while….any suggestions?
tomhrhr is offline   Reply With Quote
Old 09-19-2012, 12:10 PM   #2
Cat Fuzz
Re: 2001 Rodeo fuel leak?
It has to be one of the fuel lines. There is a supply line and a return line. There's nothing else there that can leak fuel.
99 Rodeo LS 3.5L Stroker V-6, 4wd, 31x10.5x15 2 inch Trooper lift, Aisin manual hubs.
03 GMC Envoy XL SLT 4x4 5.3L V8
Cat Fuzz is offline   Reply With Quote
The Following User Says Thank You to Cat Fuzz For This Useful Post:
tomhrhr (09-19-2012)
Old 06-11-2014, 04:58 PM   #3
arkangel1975
I have a 2001 Honda passport, which is effectively Isuzu Rodeo (the sticker inside the door says Isuzu.)
I had the same fuel leak as well, the fuel send and return lines run under the drivers seat. Mostly the line is metal, except at a few points which I believe were some sort of strain relief where the rails are connected by about 3 inches of rubber hose.
The weird thing is that the rubber get cracks and spray on the transaxle vaporizing immediately making it a pain to find.
There are a total of 4 of these points all "conveniently" located above the fuel tank. I was able to replace one by putting the car on blocks lowering the fuel tank about 2 inches with a board and a jack and reaching it, it took the better part of the day. I just had to get another replaced and the mechanic put it on the lift and swapped it and it cost me $38 for that.
Start there, I also found a leak near the fuel regulator at the back of the fuel rail.
arkangel1975 is offline   Reply With Quote
