Go Back   Automotive Forums .com Car Chat > Dodge > Ram Pickup | Ram SRT10
Thread Tools Search this Thread
Old 08-09-2005, 07:48 PM   #1
Mark1966
Unhappy 1999 Dodge ram sport losing oil
My 1999 Ram Sport is losing oil about 3 quarts every 3000 miles but no oil on the ground and can not find any leaks around the motor also no smoking out of the tail pipe tail pipe looks normal
can anyone help me I can not fix what I can not find
Mark
Mark1966 is offline   Reply With Quote
Old 08-10-2005, 10:03 AM   #2
Austin8214
Austin8214's Avatar
Re: 1999 Dodge ram sport losing oil
It has got to be burning it if you don't see it on the ground. When oil burns it does not always make the thick blue smoke. Do a compression check and see what you get if you have low compression chances are you are burning oil.
Austin8214 is offline   Reply With Quote
Old 08-10-2005, 06:35 PM   #3
Mark1966
Re: Re: 1999 Dodge ram sport losing oil
so would that mean rings or valve seats
Old 08-11-2005, 08:28 AM   #4
timbo_lan71
On the bottom of your intake manifold there is a removeable tin plate or pan,usually the gasket goes between that pan and the intake manifold then oil gets sucked in to the intake,I would put money on it that gasket is bad,the best way to check it is to block off all the hoses going to both valve covers,including the pcv line,take off the oil cap and let the engine idle,there should be no vaccum at the cap,sometimes you can lay a small piece of paper over the oil cap hole and see if it trys to suck it in.You would need to replace the lower intake gasket and intake gaskets if there is vaccum there,not a bad job....
timbo_lan71 is offline   Reply With Quote
Old 08-14-2005, 11:51 AM   #5
RacerSS
Tsb
RacerSS is offline   Reply With Quote
Old 02-23-2006, 11:41 PM   #6
dodgeitramitfreak
hey i just had to re and re a motor in my 96 ram 2500 because the person who owned it before me used a cork plenum gasket and it got sucked into the motor . that started the problem of losing oil like yours did but i didnt realize that after the plenum was repaired with a new one that was metal instead that the oil had allready gone past the pistons rings and therefore sealing the fate of the motor check your plenum gasket first and hope it didnt go any farther and they are right do a compression test that will tell you if your rings have been compromised.
dodgeitramitfreak is offline   Reply With Quote
Old 02-24-2006, 12:06 AM   #7
mechhound
How many miles on your truck? A quart every 1000 miles is not bad. Some engines just consume some oil, probably past the rings. If it doesn't get any worse, I personally wouldn't worry about it. The only way to cut consumption may be a complete rebuild, and then it may not help. OKAY, the rest of you experts on here can jump all over me now for such an answer.
mechhound is offline   Reply With Quote
Old 02-24-2006, 05:18 PM   #8
tony36
Send a message via MSN to tony36
I think you are right on the money. Every brand new vehicle I have had would go through a quart at least every 3000. Something to think about, when your dipstick reads a quart low it doesent neccessarily mean you lost or burned the oil. Oil loses its integridy running through the motor(breakdown) When this happens it becomes less dense(thinner) therefore it takes up less space and does not sit at ass high a level as when it is new. And yes, synthetic does the same. Some oils are worse than others for this. All in all if his motor is running good I would run it until it drops.
tony36 is offline   Reply With Quote
Old 02-25-2006, 04:22 AM   #9
Stevo2
Stevo2's Avatar
Jack of all trades...Master of none!
Could someone please fix my Instant Email Notification?
Please get back to us with your fix!
Why did you buy a $40K vehicle and not a $100 Factory Service Manual?
Stevo2 is offline   Reply With Quote
Old 02-27-2006, 02:46 PM   #10
Loud Pipes
plenum (intake manifold gasket). the ones from the OEM had a tendency to break down and get sucked in on the corners. Happened to my 97 Sport with 75k miles on it. Not a bad fix, just labor intensive. I also had developed a ping, and changing the plenum gasket completely eliminated it.
Loud Pipes is offline   Reply With Quote
Bookmarks
Search this Thread:
