Go Back   Automotive Forums .com Car Chat > Dodge > Ram Pickup | Ram SRT10
Thread Tools Search this Thread
Old 03-29-2005, 11:26 AM   #1
ben9@tds.net
Question 96 Dodge 3500 Cruise Control Problem
Have 5 speed Manual trans., V-10 engine, Cruise button pushed, light comes on, but when SET button pushed, CRUISE won't activate. Everything is connected @ Cruise unit under battery.Appreciate any ideas. ben9@tds.net
ben9@tds.net is offline   Reply With Quote
Old 03-29-2005, 08:04 PM   #2
1thunder
Re: 96 Dodge 3500 Cruise Control Problem
make sure you have manifold vacum at servo under battery tray
1thunder is offline   Reply With Quote
Old 04-15-2005, 12:12 PM   #3
ben9@tds.net
Thumbs up Re: Re: 96 Dodge 3500 Cruise Control Problem
1thunder was absolutely correct, THANKS! Reason should be noted tho: the vacuum hose goes under the battery & acid ate thru it.(Could happen to MANY!) Spliced the burned section with quality, slightly larger hose & problem solved. Had to R&R battery + batt. tray to accomplish this. Thanks again. Ben
Bookmarks
Search this Thread:
