09-29-2016, 01:03 PM | #1 | |
Need help 07 equinox
I'm in need of help. Having numerous issueso that all started at the same time. Hazard and blinkers stopped working, lift gate won't open and shifter will not shifting out of park. Got lift gate opened from inside to check bulbs. They were good. Checked front and one was burnt. As soon as I plug a new one in it is blown. All fuses are good. Have unplugged every thing on fuseach panels and battery and computer let sit for a few hours. Still nothing. A mechanic looked at the shifter and all he did was break it to where you can shift into gear without brakes being applied. Anyone know anything will help
09-29-2016, 03:19 PM | #2 | |
Re: Need help 07 equinox
Sounds like the Equinox (not just yours) is turning out to be quite a problem child. Try checking relays, maybe one or more of them burned out.
After you fix the problem, you may want to consider getting rid of that thing and finding something more reliable. I would avoid most domestic cars from right before the big bailout. The whole reason the big 3 needed that bailout was because of the poor build quality of so many of the cars they were making at the time and all the repairs that had to be done under warranty as well as people recognizing the problem and staying away from domestic cars. I'm guessing the warranty is long since expired and I promise you there will be more problems to come. Other electrical problems as well as transmission problems seem to be pretty common with the Equinox. More headaches, a hole being eaten in your wallet, and you as the owner doing a lot of this:
"Ok, systems check; the battery is discharging, the oil temperature is very high, the oil pressure is very low, the engine temperature is off the end of the scale, I'm running out of petrol... but the clock is correct!" -James May, in an old, worn out Lamborghini purchased for less than £10,000. |
