Go Back   Automotive Forums .com Car Chat > BMW > 3 Series
Old 12-30-2003, 02:04 PM   #1
dutchbmw
Unhappy water in oil!
Hello, I'm new on this forum................. ........so I don't know everything........
I have a problem with my beemer........... there's coolingfluid in the motoroil....
what must I do?????????????? HELP!!!
Greetzzzz Pieter
dutchbmw is offline   Reply With Quote
Old 12-30-2003, 07:35 PM   #2
Beachcomer
Re: water in oil!
Well, Pieter, how good are you with a compression tester? Are you familiar with doing a compression check? Those are some "symptoms" of a blown head gasket. If you're not currently driving it, then don't start. You RISK further engine damage. Because if engine coolant is leaking into a cylinder and you try to start the car with the uncompressible, noncombustible fluid in there, serious damage (bent valves, bent rod, cracked piston, broken rings--you get the picture. If you're familiar with the troubleshooting and repair of a head gasket (cracked or warped head, are also possibilities) then dig in. If not, get it to your favorite repair shop. It won't be cheap (mainly labor prices).
Beachcomer is offline   Reply With Quote
Old 12-31-2003, 02:47 AM   #3
dutchbmw
Hello beachcomer, thanx for your information. I think i get as soon as possible to my repair shop, because i won't have a damaged engine! Maybe I will let them check the compression first, so in order to know if the head gasket is a gonner!
1986 trooper 2 water pump replacement csurge Trooper | SLX | Bighorn | Wizard 1 11-02-2009 07:12 PM
timing belt and water pump :( cobraprince 3000GT/Stealth 17 07-09-2009 03:28 AM
Water Pump Gasket & Sealant/ Tensioner O-ring Questions Make 'em Last Grand Prix 2 06-06-2009 01:17 PM
New water/oil pump? projectgsr Let's get Technical! 1 12-19-2004 09:57 PM
