Old 05-22-2019, 07:44 AM   #16
Stubeck
Re: Tamiya Toyota TS050
Front and rear end as well as the airbox are simply put in place, but the engine cover is fitting a lot better now. I've also placed the mirrors on the car, which are a bit of a mess because of the fragility of the mirror mounts (the one on the right side is just plastic sprue) and how they dried in place. I also had to reglue on the left side number plate as that decided to become dislodged whilst putting the mirror on too.
The decal on the chrome piece actually came out pretty well despite there being a ton of film on the decal too, as its just one decal. Placing the engine fin was pretty easy, although you can see the one area I messed up a bit and need to touch up on the black
This was where I spent most of the night, with getting the lights all fixed up, the decals on the front end and the flip ups. The flip ups are way too thick and the decals don't look great on them, so next time it will definitely be thinned and painted after being on the body. I'll be making sure to polish up the transfers before putting the headlights on later this week.
Next step will be finishing up the front lights, getting the light cover on and filling in the plastic around the front end with the gaps.
Stubeck is offline   Reply With Quote
Old 05-24-2019, 08:07 AM   #17
Stubeck
Ignore the dog hair in this pic or the next one. The front headlights are pretty complicated obviously, and this shows it with the metal transfers in place.
The kit is pretty complicated and this was part of a screw up I made early on. The kit asks you to paint the outside of the headlight part in semigloss black and leave the center clear. What I didn't realize with everything else was that the metal transfer was supposed to be seen through the headlight. I tried to polish out the paint but never got it 100% clear again. I'm sure it will look better if you follow the actual directions.
I had this problem with the car and was trying to think of a way to fix it. The fix was pretty obvious.
Use putty! Yes, it doesn't look great here (this is before I cleaned it up a bit) but it will be covered by a red decal shortly.
Another test fit of the front end. I put the headlights on with simple clear paint so am giving it a ton of time to fully dry. As can be seen I still have a bit to fix with the left side headlight. The front nose is all together though which looks pretty nice. It was my first time getting CF decals to lay down perfectly.
And a much better view of the rest of the car. I fixed the rear engine cover by removing some extra plastic on the chassis. The airbox is on now as well as the exhaust and body reinforcements near the number board. Super annoyingly, I had to do some touchup painting with semigloss black on the interior of the engine cover where I didn't cover very well...right where the decals got stuck to the tape. So that was just some salt in that wound.
I'll be wrapping up the wheels next and mounting them to the car before gluing the front and rear end on the car as well as the rear wing. Then its the final step of decals and I'll be done. This will likely be the last update as my micro steps don't seem to be too interesting to most.
Old 05-26-2019, 06:50 AM   #18
potsie
Wow, this looks like a super-complicated kit. I am still keen to build one, but I will certainly do a lot of planning and test fitting. And read your wip over-and-over again!
potsie is offline   Reply With Quote
Old 05-27-2019, 08:02 PM   #19
Stubeck
I'll start with a pic of the workbench while putting the tire decals on. Once I finish this kit I'll be going on vacation shortly so plan to concentrate on working on my bench to clean it up and make it more useful.
The wheels are two parts and goes together easily. The mold line on the tires is extremely faint, but just like the Williams kit I made a mess of sanding the tires down. I need to figure out a new process for this. The wheels originally were Alcad Gunmetal but this proved too dark so I used steel which came out a lot better color. Next time I'll get a better gloss coat on the wheel nuts to get a better chrome coat on. The tire decals went on pretty well but I still rush them so they're not as perfect as I'd prefer. After letting them dry for a day I use elmers glue as a matte clear coat.
Going back a few weeks for the headlights I used my own masking so its not 100% perfect, but it would have been so much worse with the kit included mask which was 3 parts! Two masks are for the sides and one for the center. Its hard to see through pictures but they're incredibly complex designs so its not as simple as just getting a piece of blue tape and laying it down. I'll hopefully learn and do a better job next time. I used clear paint to secure the headlights.
And now its together! While tinkering with the body I realized that the right side number plate part is too far forward. Unfortunately its too secured to move it. I made sure to place this wheel first, and it touches the tire but is otherwise OK.
The top body work clips into holes in the number placards which I thinned slightly. I initially had issues with the two notches from the chassis which go into the nose bodywork keeping the nose from securing properly, so I separated it out, thinned out where the connection is made and got the bodywork down as well as it would go (there is a big gas that is my own fault. After I felt confident the nose parts were secure I placed the splitter on. This went together a lot better than I was expecting. There was a bit I needed to touch up on the side of the nose.
I also got the fuel filler, engine cover and antenna on. You can see where the mirror mount part isn't mounted properly on the right side. The engine cover came together really well though. There is a bit that isn't perfectly painted but with all of these body parts that was never going to happen.
When I build the kit again I'm considering putting almost all the bodywork together prior to painting. There are some pieces that would need to be kept separate but overall more can be put together than the instructions call for. A lot of those which are kept apart to paint the interior pits are impossible to see for example, such as the number placard interior or even 90% of the nose/engine pay.
Next steps are to put the red decals on, as well as the Indycals WEC and Le Mans decals, the rear wing and then a few antenna parts.
Old 05-31-2019, 08:06 AM   #20
Stubeck
I'll start with an in progress shot as I took away one of the decals while polishing! There weren't really any dramas with the decals, although the red decal that goes on the fenders was not very easy to put on. I think there is a slight gap on the right side fender but its very hard to see. I did use the Indycals decals for the number plate 24 Le Mans/Total and the WEC decal. They are a bit oversized but overall look good. Their decal sheet does include number plates with the Le Mans/Total integrated, but I felt the quality of the Tamiya decal was better so used the fill in.
And its complete! The rear wing was a lot harder than I was expecting to complete. Its become apparent during this build that I used too much paint basically everywhere, which is why stuff doesn't fit like it should. This extended to the rear wing endplates, which never really fit properly. I took this apart about 4 times and ended up somewhere where I wanted to. What is nice is that even with the screwups, the rear wing endplates hold it in really well, so I didn't even technically need glue for this. I used white glue for the fin part and super glue to keep the endplates in.
You can see some of the other areas I struggled in on this side too. The number plate is askew a little, and somehow I glued the mirror support/P1 part about a quarter inch off of where it should be. This made some of the issues there look worse than they probably should have. I'm happy with my replacement mirror support though. I still need to get better about making the small changes necessary to straighten out decals as I can see some of them are just slightly askew, and with the magnification these photos give they look a lot worse than they do in real life.
As I said the decals laid down pretty well. I still had a few areas where I got wrinkles, and the area around the huge gap looks a little terrible, but I figure its better than having the gap all the way across. While the Toyota decal on the chrome came out just fine, the finger print underneath it is now there for the ages. While polishing the black decal came off on the air inlet, and I'm just going to let it be.
You can see here where I struggled with sanding the tires. I think I actually made it worse as the original line is very slight on the tire, and nothing I was doing was making it any better, so I just moved on. I'll play with some NASCAR tires before my next build to get better at this process. Lots of gaps as can be seen, but even with missing a few decals it looks good.
Rear end view shows some more struggles but overall the shape is good. I'm particularly happy with the chrome on the rear wing that can be seen. Its a miracle that I got the red decal to go over the ridge and cover the white on the fin.
And the rear view. I know the lighting is terrible!
I'm going to take better pictures with a DSLR before I post in the completed car forum.
I obviously learned a lot on this build! Here's a quick list:
1. Don't follow the instructions to a T! Putting together several of the body parts before painting would have helped tremendously on the gaps you see in the final build, helped with completing the build quicker, resolved several problems I had with paint lines not matching, and also helped with some of the fragility of the final build.
2. Paint interior colors first...and also make sure they need to be painted. There is no reason I needed to paint the interior of the number plates, the airbox or much of the rest of the interior because its never going to be seen. All that really needs to be painted is the interior of the car (and even that is only the front half), the wheel wells and part of the engine cover.
3. Don't use 3M blue tape on completed parts. Or stick it to your body first to take away some of the tackiness. It took apart 3 decals and then I still wasn't 100% happy with the coverage on the interior.
4. Use less paint. I'm terrible with painting white and this led to my problems outlined above. I have some vacations coming up in the next month so since I won't have much time to actually progress on another build, I'm going to play around with painting on a plastic spoon and learning from that.
And here's what I'd recommend for anyone building the car in the future.
1. Put it together first! Almost the entire body can be glued together before you need to paint anything. The instructions have you wait a long time for many of the parts, but even if you don't have the gap issues I had, you'll have lines in places that are completely unnecessary, it also makes painting that much harder. I'd also include putting the front suspension on as part of this process, and using a chrome pen for the exposed suspension parts. You won't be able to see them on the final build anyway.
2. Don't spend much time on the interior. You won't see much of anything anyway unless you open the doors. I probably spent half an hour detailing the wheel and you won't ever see any of it!
3. Paint the red parts of the car. You already have to do so much masking with the black, that doing the red isn't a huge addition. It won't save a ton of time as the included decals are quite good, but it'll look better. Aftermarket decals are coming out which include the HY and P1 decals separate too.
Thats about it. Hoping you liked the process and I'm sure we'll see some amazing builds of this kit soon! I'm planning to get another version and replicate the 2019 design.
The Following User Says Thank You to Stubeck For This Useful Post:
Martini Man (05-31-2019)
