Go Back   Automotive Forums .com Car Chat > Dodge > Ram Pickup | Ram SRT10
Closed Thread Show Printable Version Show Printable Version | Email this Page Email this Page | Subscription Subscribe to this Thread
Thread Tools Search this Thread
Old 05-17-2005, 11:42 AM   #16
fredjacksonsan
Caution: Monkeys bite!
fredjacksonsan's Avatar
Send a message via AIM to fredjacksonsan
Re: Multiple missfiring
Someone I know with a similar problem had a bad camshaft position sensor, so that's worth a check.
Hers: 2018 Ford Flex Limited AWD, 36k
His: 2015 Toyota 4Runner 4wd, 60k
fredjacksonsan is offline
Old 05-17-2005, 12:59 PM   #17
1999RamTuff
Originally Posted by f250e350
didnt you say you did test your ignition coil?? did you also say the readings on the coil were to high??....hmmm...well....it is only a $29 piece....well....???
They were on the high side but within tolerance. I'll change it and see what happens.
1999RamTuff is offline
Old 05-17-2005, 07:55 PM   #18
1999RamTuff
OK, I changed the ignition coil and sparkplug wires. The wires are the second set. These are 8.5mm. Made sure of the seperation when I installed them. Still, no help. I am beginning to wonder if the catalytic is causing my problem.
Old 05-17-2005, 09:19 PM   #19
TurboSW
TurboSW's Avatar
Re: Re: Multiple missfiring
You should go to a shop and ask them to remove it and then let you drive it around for a second to see if it is. Don't just have them replace it.
TurboSW is offline
Old 05-18-2005, 10:13 AM   #20
1999RamTuff
Re: Re: Re: Multiple missfiring
I have it scheduled at the dealership for tomorrow. AAARRrrggghhhhh!
Old 05-18-2005, 10:14 AM   #21
fredjacksonsan
Let us know.....
Old 05-18-2005, 03:12 PM   #22
f250e350
sounds like a pain to find out what the problem is....only on a dodge!!!
f250e350 is offline
Old 05-18-2005, 05:26 PM   #23
TurboSW
TurboSW's Avatar
Re: Re: Re: Re: Multiple missfiring
Why would you take it to a dealer?
TurboSW is offline
Old 05-18-2005, 10:45 PM   #24
kev2500
had the same problem on my 02 just curious - what kind of plugs are you using. mine runs terrible with anything but champions. dealership has had a lot of problems with other brands causing misfires. bosch platinums made mine misfire terrible
kev2500 is offline
Old 05-23-2005, 10:44 AM   #25
1999RamTuff
I use the OEM champion plugs. I have changed the camshaft sensor and the #8 cylinder sparkplug again just for the heck of it. I did drive it up to Dallas from Houston and I never got the check engine light. It ran pretty good actually. I will wait to see how it does up there. I did talk with a mechanic at the dealer and he said it may be a blown head gasket. Haven't checked that yet. I will have to perform a cylinder compression check to see.
Old 05-24-2005, 08:30 PM   #26
f250e350
good way to tell if its a blown head gasket is to check the oil....check for engine coolant in the oil and check the level of the oil IE: oil level above the mark you might have a blown head gasket
f250e350 is offline
Old 05-25-2005, 12:31 PM   #27
Austin8214
Austin8214's Avatar
This is not always the case. The gasket blowing does not always let water into the oil.
Austin8214 is offline
Old 05-29-2005, 12:19 AM   #28
1999RamTuff
Unhappy
OK, I started to get a flashing check engine light, so I took it to the dealer on Friday. They said I had missfire codes on 7 out of 8 cylinders. I went back to OEM mopar parts on the distributer cap, wires and rotor. I drove from Houston to Dallas this weekend and it is still hard to start and is running rough on the lower rpms. I'm gonna check for a blown intake manifold gasket tomorrow. I want to get a compression check on the cylinders to see where I'm at with that.
Old 06-24-2005, 01:30 PM   #29
1998Ramtuff
1998Ramtuff's Avatar
Unhappy
My move to Dallas was a success. My truck is back at the dealer. I explained everything that has been done. The dealer in Houston told me the anylizer came up with multiple missfires on 7 out of 8 cylinders. I have replaced everything I did previously with OEM Mopar components. Still nothing. The mech thought possible headgasket blown 2 ea. or blown intake manifold gasket. I checked the intake when I got up here and saw no oil in the plenum. I am keeping my fingers crossed and my pocket book handy.
1998Ramtuff is offline
Old 06-24-2005, 01:59 PM   #30
fredjacksonsan
I have a long shot...you said it runs rough at low rpm, and hard starting. On the older Mopar motors, the timing chain would stretch enough to cause the problems you're having. It's worth a check to open the timing chain cover and see if there's slack in the chain.
Closed Thread
Bookmarks
Search this Thread:
