03-06-2009, 05:37 AM | #1 | |
common repairs times : 96 Acura Integra 1.8 PFI auto
I want to know what some of the more common repairs times are concerning this vehicle
96 Acura Integra 1.8 PFI auto Tune up - lower ball joint - upper ball joint - F strut - R strut - generator/ altenator - starter - radiator - battery - should be a quick guess of 15 -20 minutes coil spring f - coil spring r - valve cover gasket - timng belt/chain - brakes f - brakes r - a/c compressor - coil pack - shock/strut - shock/strut - Wheel bearing - egr - oxygen sensor - thermostat - water pump - thanks in advance |
08-13-2010, 03:35 AM | #2 | |
Re: common repairs times : 96 Acura Integra 1.8 PFI auto
Tune up - lower ball joint - upper ball joint - F strut - R strut - generator/ altenator - starter - took 30 - 45 minutes radiator - took approximately 30- 45 minutes battery - should be a quick guess of 15 -20 minutes coil spring f - coil spring r - valve cover gasket - timng belt/chain - brakes f - brakes r - a/c compressor - coil pack - shock/strut - shock/strut - Wheel bearing - egr - oxygen sensor - thermostat - water pump - add to this list rotors front - about 30 minutes for each side |
08-13-2010, 06:02 PM | #3 | ||
Those are all pretty accurate as to what we would charge. Does it actually take that long? Usually not if you know what your doing and have done it before, plus having all the right tools. |
Thread Tools | |
