02-17-2006, 12:09 AM | #1 | |
check engine/transmission lights
hey my check engine light goes on when i am at speeds above about 60-65mph. anybody have this happen to them or have any ideas on what this might be
another thing when it rains real hard and i am driving at highway speeds my check transmission light comes on. am i correct to assume that this is just probably water causing a short in a sensor or something of that sort. it started happening after i took the lower engine shroud off and all the screws broke and now i have no way of putting it back on without drilling out the screws
1999 VW Golf GLS 1988 JEEP Cherokee 4WD |
02-26-2006, 11:54 AM | #2 | |
Re: check engine/transmission lights
please help me....i will love you long time!
01-02-2007, 01:45 PM | #3 | ||
Pull the CEL codes follow this linkhttp://forums.nicoclub.com/zerothread/60332 Pull the AT codes; follow this link. http://forums.nicoclub.com/zerofile/...J30atcodes.JPG Then ; How to interprit the AT codes: There are going to be a series of flashes..... The flash that is the longest is the code that you are concerned with... For instance code 5 would look like this -- -- -- -- ---------- -- -- -- being that the 5th flash is the longest.. the light wil blink a total of 12 times. Code readouts 1. Revolution sensor 2. Vehicle speed sensor 3. Throttle position sensor 4. Shift solenoid A 5. Shift solenoid B 6. Overrun clutch solenoid 7. Torque converter clutch solenoid 8. Fluid temp sensor or AT control unit powersource malfuntion 9. Engine speed signal 10. Turbine revolution sensor 11. Line pressure solenoid 12. Engine control circuit
The fleet; 01' Suburban LT 01' Dodge Intrepid 03' SVT Focus 94' Infiniti J30 |
07-17-2007, 05:02 PM | #4 | ||
Re: check engine/transmission lights 16????
When start AT lights blink 16 short times, not a single long one.
Transmission sometimes doesnt shift from 1 to 2, or 2 to 3, not sure, but rev at red line about 6-7rpm. Turn car of and on and its fine again. What can it be? Thank you!!! Quote:
