Go Back   Automotive Forums .com Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 03-31-2012, 07:36 AM   #1
02GreenMonster
Front End Clunking in Steering Wheel
Hello all,
Just purchased a 2002 Ram 2500 5.9 4x4 Regular Cab. When the steering wheel is turned to passenger side and I hit a bump I feel a clunk in the steering wheel. No noise, just the feeling in the steering wheel. I popped off the tire and checked for play from side to side and up and down. No play what so ever. All solid. I would think my ball joints ans bearings are ok then...but where is this clunking coming from? Next I thought of the track bar? But the truck is steady on the road no wondering or wobbling.. Possibly the shock? The truck has 52,800 miles on it, so right about time to change the shocks anyhow. Just wanted to see if anyone else experienced this..and if it possibly is a characteristic of the truck...being a normal issue. Thanks..
02GreenMonster is offline   Reply With Quote
Old 04-01-2012, 07:09 PM   #2
Chris Stewart
AF - Advisor
Chris Stewart's Avatar
Re: Front End Clunking in Steering Wheel
With the engine off the whole time, jack up the front end, set your jack stands then have someone turn the steering wheel for you while you observe the steering components.
My track bar was bad.
1992 Bravada, 201K, stock
1997 Bravada, 101K, stock...was "called away"
"Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14
Time to turn so's you don't burn.
Chris Stewart is offline   Reply With Quote
Old 04-02-2012, 05:36 PM   #3
02GreenMonster
Thanks for the reply,
Just got the truck back from the dealer that I purchased it from. Turns out it was the front brake calipers binding and clunking when retracting. They replaced the two front calipers for free and looked everything else over as well. lets hope this is the only issue I have with the truck...
Old 04-02-2012, 07:30 PM   #4
Chris Stewart
AF - Advisor
Good news, thanks for the update!
Old 04-07-2012, 06:05 AM   #5
02GreenMonster
Ok well had the truck 3 days and the sound started to appear again...LOL. So i took it back to the dealer and the took a ride with the service tech. He felt what I was talking about and described it as a loose feeling in the steering wheel. He is also thinking it may be an issue with the steering shaft from the knuckle to the steering box...we will see, I will keep you guys updated
Old 04-11-2012, 10:12 AM   #6
02GreenMonster
ok heres the deal,
The dealer identified the problem as normal slack/wear in the steering shaft from the column to the steering gear. Apparently there is a core inside the stearing shaft that will develope slack over time. They said this is not a safety issue. Anyone ever heard of this cause I think it smells really bad....
Old 04-11-2012, 08:00 PM   #7
Chris Stewart
AF - Advisor
I don't see a "core", just a shaft that starts at the steering wheel and ends up at the steering box with a coupler in between.
Here's a downloadable 2001 service manual.
The download is kinda slow but worth the wait.
http://dl.dropbox.com/u/42304/2001DodgeRam.pdf
Steering troubleshooting starts on page 1595
Old 04-14-2012, 07:48 AM   #8
02GreenMonster
Dude you rock, Thanks!
Creaking Noise At Front-End el ratfink Pacifica 2 12-05-2009 11:57 AM
Clunk in Front End 97 Blazer Massguy Problem Diagnosis 3 07-05-2009 08:02 AM
Front end clunking shoeman502 Windstar 9 05-06-2008 06:16 PM
Obnoxious Front End/LH/Steering Clunk 2000 LeSabre, How Loud Might A Bad CV Joint Be? pcmos LeSabre 8 10-23-2005 10:31 AM
At wits end with front end clunk pjorm Blazer 6 12-19-2004 04:23 PM
