| Latest | 0 Rplys |
05-16-2009, 12:42 AM | #121 | ||
Re: Panoz goes to Performance Autosport for some go fast stuff...
Brian B. Panoz GTRA - LS1 swap in progress #4 Z06 - NASA ST3/TT3 |
05-16-2009, 06:50 AM | #122 | |
the front looked like it was attachec directly to the frame/heatshield
Eric H (in case you couldn't guess) GT-WC #22 (now #62 and Blue) |
05-16-2009, 11:38 AM | #123 | |
It's not.... it was just the angle... the pic I posted above is how it is.
05-16-2009, 06:12 PM | #124 | |
Brian,
Yes the photo makes it look like it is solid to the frame. The hanger is not visable. However I still have a problem with that style hanger. I broke the same hanger two weeks ago. That hanger is designed to hang exaust at the rear of a car where the exhaust doesn't move. You need an hanger that can flex up and down. I used an o-ring style hanger that can flex about 1.5 inch up and down. David |
05-17-2009, 07:35 AM | #125 | ||
Mike |
05-17-2009, 02:55 PM | #126 | |
Duke,
Parts sourse would be your local exhaust shop. Just ask to see there selection of hangers. The oring style I used are 1/2 in wide by 2 in OD. I used two on each side. You will also need four J hooks two per side. Weld one hook on the exhaust pipe facing up and the other to the frame facing down. The oring act like a shock between the two J hooks. David |
05-18-2009, 08:44 AM | #127 | |
David could you shoot a picture of your setup when you have the time? I think I'm just going to run the car as is and monitor it. I'll most likely pull the side pipes this winter to install more substantial mufflers.
05-18-2009, 05:10 PM | #128 | |
my car has a flex splice on the driver side to help with flex (looks like braded wire-about 1/2" thicker than the tube. Just a head of the hanger... also put bolts in the motor-mount (as per earlier post) thanks for the tip..bill
05-18-2009, 05:25 PM | #129 | |
All the talk about the tail pipes makes me want to chim in. I thought about getting some headers but could not justify spending a minimum of $500.00 sow we have came up with the idea of leaving the stock manifolds which are not all that bad and up size the pipes to 3" dia and see what that adds if anything when we go back to the dyno. Has anyone tried this?
05-18-2009, 08:33 PM | #130 | |
Can you elaborate on "bolts in the motor mount"? I've had zero issues w/ the mounts so far. Mine look fresh and new. They're just rubber blocks.
05-18-2009, 09:44 PM | #131 | |
the motor mounts tear all the time.....I think we have gone thru about 4 pairs....
not great!
Brian G. 2000 Panoz GTS #420 NASA ST1 427ci Stroker |
05-18-2009, 10:16 PM | #132 | ||
Kel.
Kel M Panoz GTRA #17 New Zealand |
05-18-2009, 10:25 PM | #133 | |
PICTURES! What do you consider the side of the mount?
I thought the fexible mounts where used for a reason????? why not just switch to the solid mounts? we dont have the cold air system? Havent come up as something to buy yet :-)
05-18-2009, 10:57 PM | #134 | ||
We found the cold air system worth a few mph. Definitely affected jetting and rpm so all good. Kel.
05-18-2009, 11:15 PM | #135 | |
I'm in for the pics of this mod!
