Go Back   Automotive Forums .com Car Chat > Panoz > GTRA / GTWS / GTS
Old 06-08-2009, 10:47 AM   #46
tccoupe
Re: Parts list/application/source
Originally Posted by Jim woodruff View Post
Rear Wheel bearings and seals- Can someone please post the rear wheel bearing and seal part numbers.
WOODY - All the rear end stuff came from Coleman Racing Products 800-221-1851. You have the (wide 5) hub set up. You should also order the axle washer. You set these up just like front wheel bearings. You may also want to order the special socket adaptor to tighten the axle nut. makes setting the bearing up easier. I'm at the office and don't have the coleman catalog here or I'd get you the part #'s. Let me know if you run into problems... Bruce
tccoupe is offline   Reply With Quote
Old 06-23-2010, 04:36 PM   #47
Jim woodruff
Jim woodruff's Avatar
I need to know where to purchase the pins that hold the rear brake pads in place and the part number. I don't want to use these pins to many times. Thanks
Jim Woodruff
Akron, Ohio
Jim woodruff is offline   Reply With Quote
Old 06-23-2010, 05:42 PM   #48
NZGTRA17
Jim, love the paint job. Very retro cool colour to use.
Kel.
Kel M
Panoz GTRA #17
New Zealand
NZGTRA17 is offline   Reply With Quote
Old 06-23-2010, 06:58 PM   #49
jmimac351
jmimac351's Avatar
Jim, you could call PAD or try these guys in Mooresville, NC. Supposedly they are the distributor for North America. VERY helpful - especially Dennis in Technical Support.
http://www.prosystembrakes.com/
Jim McGovern
~ Building 289 Lemans Replica
~ '92 Mustang Coupe: 347ci / Carb
Pictures
jmimac351 is offline   Reply With Quote
Old 06-23-2010, 08:07 PM   #50
Rich F
Just purchased Fox body Mustang mounts for my GTS 351 car. They match the mounts I took out of the car during an engine rebuild. I purchased Energy Suspension 1122-R mounts.
Rich F is offline   Reply With Quote
Old 06-24-2010, 06:32 AM   #51
Jim woodruff
Kel.
Thanks for the info on the pins I had one break on my 911 at Road Atlanta and it was not something that i would like to have happen again. Kel the paint is 1970 Ford Grabber Orange.
Jim Woodruff
Akron, Ohio
Old 06-29-2010, 03:24 PM   #52
Jim woodruff
Here is the information on the rear calipers for our WC cars
Brembo Part number 20.7784.31 left
20.7784.41 right
Drive pin part number two required for each caliper Brembo# 20.5116.40
Pad has the parts the pin are $3.20 each
Jim Woodruff
Akron, Ohio
