| Latest | 0 Rplys |
04-30-2008, 07:50 AM | #1 | |
oil around spark plug boot???
I recently did a spark plug change all the plugs were fine but the plug nearest the oil fill cap had oil down in the spark plug hole. It was about half filled with oil, I removed the boot, sucked out the oil and replaced the spark plug and re-assembled. Runs great what gives on the oil gathering in that area?? Any ideas let me know. Thanks.
04-30-2008, 05:05 PM | #2 | ||
Re: oil around spark plug boot???
what year is your trooper? on early genII troopers (1992 - ) isuzu came up with a mickeymouse fix to avoid paying for removing all those valve covers and replacing all those seals -- namely a special set of ignition (spark plug) wires with fat connectors with ribs that seal the oil that does get in the tube , to seal that oil from shorting out the plugs. you can buy them from isuzu, and i've seen a post that they may be available from other sources. btw, if you do install them, from a known isuzu expert JLEMOND coat the OUTSIDE of the connectors with antiseize and the INSIDE with dielectric grease. otherwise they are all but impossible to remove when you need to. these connectors work, but if its real bad you need to think about removing the vc and replacing those seals and use the new fat connectors also. //bc
1992 trooper 3.2L v6 sohc automatic...as is i love a good intermittent electrical challenge. . .especially when it's someone else's. |
04-30-2008, 07:43 PM | #3 | |
My trooper is a 1998 with the 3.5 v6. Boy that sucks that I have to remove the valve cover to fix just one. Oh well could be worse I guess. Who can I get these seals from, we have no local Isuzu dealers, or should I just search the net? Thanks.
05-01-2008, 12:43 AM | #4 | ||
http://isuzu.stcharlesauto.com/Department-Parts.aspx or go to another forum http://forum.planetisuzoo.com/index.php and PM JLEMOND a genuine isuzu expert guru who was an isuzu tech trainer and very knowlegeable and sells genuine isuzu parts for less. also UNDERDOG at the same forum, PM him, he's a parts guy at a dealership in oregon. also free shipping, some incredible discounts. of course get the vc gasket (s) and any other gaskets/seals you will need, depending on what you end up removing hth //bc
The Following User Says Thank You to trooperbc For This Useful Post: |
mtnbiker66 (01-29-2012)
02-27-2010, 11:11 AM | #5 | |
Wow. I never realized they had a quick fix for this! When I first got my 1996 Rodeo, I pulled the valve covers and replaced the valve cover gaskets, but I did not replace the gaskets at the spark plugs. I did not know about the spark plug area oil leaking problem or I would have fixed it then; it was a difficult job for me changing the valve cover gaskets, a chore that would have been very easy for other makes of vehicles. I even had to pull off the intake. I will definitely look for the special plug wires!
03-02-2010, 07:48 PM | #6 | |
AF -Advisor
Give St Charles Isuzu a shot for the parts, they are great to deal with.
84 4Runner - ARBed 5.29s F&R, 4.7 & 2.28 t-cases, Chevys, AP x-over, BudBuilt x-member, 2" drv trn lift, 36" TSLs, 30 spline Longs 80 something p/u - Buick 231 V6/TH-350 trans, Holley 4 bbl, Weiand intake, dual batts, dual tanks ... 89 4Runner - stock 2000 Isuzu Trooper + 2010 Sonata |
09-01-2011, 01:56 AM | #7 | |
Replacing the plug wires? My Rodeo has 6 coil packs, not plug wires per se.
Big time oil leaking on threads of spark plugs #1 and #6 T C |
