Old 04-10-2004, 02:35 AM   #1
M@St3R_D
Question The Tuning Numbers
For serious engine tuners like me, we often do mods on our motors. When we modify something, it affects the way the engine runs physically (Stress, Power, A/F, R/S, C/R, etc) You probably understand what I mean... Can anybody who knows the calcutions (math equations)related to every aspects of tuning to list these formulas in this thread??? That would help a lot of in-depth tuners like me in their projects and maybe become a reference... Thanks a lot guys!!!
M@St3R_D is offline   Reply With Quote
Old 04-10-2004, 07:51 AM   #2
almxdupintegra
Re: The Tuning Numbers
almxdupintegra is offline   Reply With Quote
Old 04-11-2004, 09:47 AM   #3
jcrx
Send a message via AIM to jcrx
Re: Re: The Tuning Numbers
Originally Posted by almxdupintegra
You need to work on your linking skills homie...
www.importreview.com
If you're an "in-depth tuner" you should already know this. :P
Here, have fun...
Formulas for displacement, bore and stroke:
cylinder volume = pi/4 x bore^2 x stroke
stroke = displacement / (pi/4 x bore^2 x number of cylinders)
Formulas for compression ratio:
(CylVolume + ChamberVolume) / ChamberVolume
chamber volume = cylinder volume / compression ratio - 1.0
displacement ratio = cylinder volume / chamber volume
amount to mill = (new disp. ratio - old disp. ratio / new disp. ratio x old disp. ratio) x stroke
Formulas for piston speed:
piston speed in fpm = stroke in inches x rpm / 6
rpm = piston speed in fpm x 6 / stroke in inches
Formulas for brake horsepower:
horsepower = rpm x torque / 5252
torque = 5252 x horsepower / rpm
brake specific fuel consumption = fuel pounds per hour / brake horsepower
bhp loss = elevation in feet / 1000 x 0.03 x bhp at sea level
Formulas for indicated horsepower & torque:
horsepower = mep x displcement x rpm / 792,00
torque = mep x displacement / 150.8
mep = hp x 792,000 / displacement x rpm
mechanical efficiency = brake output / indocated output x 100
friction output = indicated output - brake output
taxable horsepower = bore2 x cylinders / 2.5
Formulas for air capacity & volumetric efficiency:
theoretical cfm = rpm x displacement / 3456
volumetric efficiency = acutal cfm / theoretical cfm x 100
street carb cfm = rpm x displacement / 3456 x 0.85
racin carb cfm = rpm x displacement / 3456 x 1.1
Formulas for tire size & their effect:
effective ratio = (old tire diameter / new tire diameter) x original ratio
actual mph = (new tire diameter / old tire diameter) x actual mph
Formulas for g force & weight transfer:
drive wheel torque = flywheel torque x first gear x final drive x 0.85
wheel thrust = drive wheel torque / rolling radius
g = wheel thrust / weight
weight transfer = weight x cg height / wheelbase x g
lateral acceleration = 1.227 x raduis / time^2
lateral weight transfer = weight x cg height / wheel track x g
centrufugal force = weight x g
Formulas for shift points:
rpm after shift = ratio shift into / ratio shift from x rpm before shift
drivehsaft torque = flywheel torque x transmission ratio
Formula for instrument error:
actual mph = 3600 / seconds per mile
speedo error percent = difference between actual and indicated speed / actual speed x 100
indicated distance = odometer reading at finish - odometer reading at start
odo error percent = difference between actual and indicated distances / actual distance x 100
Formulas for MPH RPM gears & tires:
mph = (rpm x tire diameter) / (gear ratio x 336)
rpm = (mph x gear ratio x 336) / tire daimeter
gear ratio = (rpm x tire diameter) / (mph x 336)
tire diameter = (mph x gear ratio x 336) / rpm
Formulas for weight distribution:
percent of weight on wheels = weight on wheels / overweight x 100
increased weight on wheels = [ distance of cg from wheels / wheelbase x weight ] + weight
Formulas for center of gravity:
cj location behind front wheels = rear wheel weights / overall weight x wheelbase
cg location off-center to heavy side = track / 2 - [ weight on light side / overall weight ] x track
cg height = [ level wheelbase x raised wheelbase x added weight on scale / distance raised ] x overall weight
jcrx is offline   Reply With Quote
Old 04-11-2004, 02:48 PM   #4
M@St3R_D
Re: Re: Re: The Tuning Numbers
Lol, your right about this but every "in-depth tuner" gotta learn somewhere so... Lets say I want to BECOME an "in-depth tuner" Thanks a lot for your help jcrx I really appreciate that you help me getting more skillful I will come back later with questions about some equations 'coz I gotta go...
