Go Back   Automotive Forums .com Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > C/K
Old 04-21-2018, 10:10 PM   #1
Lordzeil1
1976 GMC truck c/k 15 Engine Vacuum
Hey all just curious if knows the vacuum layout for a 350 small block, Sadly not sure on the carb type but will most likely throw in a new two barrel in. truck has no efe system but everything else is there
Lordzeil1 is offline   Reply With Quote
Old 04-22-2018, 09:09 AM   #2
Schurkey
Re: 1976 GMC truck c/k 15 Engine Vacuum
At one time, there would have been a hose-routing decal under the hood. It may be missing now.
Should also be in the service manual.
If not, it's not too hard to figure out based on the needs of the devices connected to vacuum, and the available vacuum ports.
For the good of the Free World, DEMAND COMPENSATION FROM CHINA for their release of the Virus Originating in the Wuhan Laboratory, released (intentionally or negligently) into the world in 2019 (VOWL-19). Ten trillion to start with, increasing as needed from there, PLUS compensation for the sickened, and "wrongful death" settlements for the families of those who didn't survive. END trade with Communist China.
Schurkey is offline   Reply With Quote
Old 12-26-2018, 12:02 PM   #3
fast68chevy
real simple only have two choices,, ported, IE above throttle blades vacuum at higher RPM, and direct high vacuum at idle only. distrib vac advance usualyl needs to be ported and vacuum later on higher in RPM to advance the timing some alongside the mechanical weights advance too. other things like fuel vapor and EGR have solenoid or switch electrical controlling vacuum so it can provide vacuum to them only at certain temps and at certain levels of vacuum as well, and what not..
complete '77 Dodge 440-4bbl w/ headers engine(for sale), '75 C20 pickup, '93 Lumina APV 3.1L 3T40E 106K miles needs a/c compressor, subframe mounts broken. text 217 737 0942
fast68chevy is offline   Reply With Quote
