Thread Tools | Search this Thread |
#61 | |
Re: OBD Code Definitions 1993 Trans Sport
Here is something I came across on the net, not sure if you have already done the test, or if it might be of some value to you https://easyautodiagnostics.com/gm/4...-valve-tests-1
#62 | ||
In the 200 Club
How often do the PROM(s) crap out?
1923 Model T 'Stake' Truck, see in Legends of the Fall 1949 Chevy 3/4 Ton, had 214 ci now 235ci 1959 Dodge Mayfair 1986 Ford Ranger 4 cyl 1993 Pontiac TransSport 3.8 1996 Chevy 3/4 Ton 4x4 1999 Oldsmobile Alero 2004 BMW 330i Last edited by tinkering; 12-30-2021 at 12:46 PM. |
#63 | |
Proms seem to be quite robust, don't hear much problems with them as as a rule That being said, they can be damaged by electrical static discharge, critically important that you be thoroughly grounded to the PCM. They are also subject to physical damage while removing or installing, be careful doing that.
Did all these trouble codes show up all at once, or gradually one at a time over a period of time? |
The Following User Says Thank You to Jeffrv For This Useful Post: | tinkering (01-06-2022) |
#64 | ||
In the 200 Club
I am going to be recovering for awhile now. I'm in the hospital with covid pneumonia at present. Parts are in though👌
1923 Model T 'Stake' Truck, see in Legends of the Fall 1949 Chevy 3/4 Ton, had 214 ci now 235ci 1959 Dodge Mayfair 1986 Ford Ranger 4 cyl 1993 Pontiac TransSport 3.8 1996 Chevy 3/4 Ton 4x4 1999 Oldsmobile Alero 2004 BMW 330i |
#65 | |
In the 200 Club
I am on the mend. We were part of the not quite as lucky; the china virus had me in the hospital for 10 days (no ICU).
The new computer did nothing for the Trans Sport. The engine light is still on. It idles terribly rough still. I don't know where to start now. I guess I have to go back to the beginning; read this whole thread again; double check stuff. Dang it.
#66 | |
In the 200 Club
Here is my approach now.
The DTCs are 17,18,26,56. I think I should work on the 17 and 18 codes first before the Quad Driver A and B codes 26 and 56. DTC 17 Spark Reference Circuit could be related to the Crankshaft Sensor; It could be a defective Ignition Control Module too. DTC 18 Cam/Crank Error is self explanatory. I am going to replace the Cam Position Sensor firstly, because it is the easiest. Then the Crank Position Sensor if needed. I saw on utube, a problem with the camshaft position sensor connector and the pigtail wires inside the harness, where oil had destroyed the insulation; they had been shorting. I will explore that too. I need to check the wires, voltages, and connectors too. It is idling rough intermittently; it starts poorly intermittently, kicks back on the starter sometimes. All this should take care of DTCs 17 and 18, then I will carry on from there with DTCs 26 and 56, the Quad Driver codes. What does the abreviation CKT mean in the GM service manual? ie. CKT 647. 'Connector'? I can't figure that out. Have to take a break from the manual��
1923 Model T 'Stake' Truck, see in Legends of the Fall 1949 Chevy 3/4 Ton, had 214 ci now 235ci 1959 Dodge Mayfair 1986 Ford Ranger 4 cyl 1993 Pontiac TransSport 3.8 1996 Chevy 3/4 Ton 4x4 1999 Oldsmobile Alero 2004 BMW 330i Last edited by tinkering; 02-13-2022 at 06:18 PM. |
#67 | |
Registered Offender
![]() Join Date: Mar 2006
CKT - Circuit
The Following User Says Thank You to Blue Bowtie For This Useful Post: | tinkering (02-15-2022) |
#68 | |
In the 200 Club
Do the codes clear on their own on that old OBD1 system, or do you have to clear them yourself? I changed out the camshaft position sensor but the light popped on again
1923 Model T 'Stake' Truck, see in Legends of the Fall 1949 Chevy 3/4 Ton, had 214 ci now 235ci 1959 Dodge Mayfair 1986 Ford Ranger 4 cyl 1993 Pontiac TransSport 3.8 1996 Chevy 3/4 Ton 4x4 1999 Oldsmobile Alero 2004 BMW 330i Last edited by tinkering; 02-17-2022 at 02:36 PM. |
#69 | |
In the 200 Club
Ok, here is the update.
I don't know if the codes cancel on their own after repairs. I had the negative battery terminal undone so that might have cleared the codes. (Diagnostic trouble codes may be cleared by disconnecting the battery ground cable for at least 20 seconds. Reconnect negative battery cable and recheck codes to confirm the repair.) After replacing the camshaft position sensor, codes 17 and 18 no longer are present. Hooooray! Unfortunately codes 26 Quad Driver A and 56 Quad Driver B are still present. I have a couple more possibilities to try that I found. See GM TransSport Service Manual Book 2 p. 6E3-A-48 etc. I will post again later, when I get that plan figured.
#70 | |
In the 200 Club
In following the GM TransSport Service manual, and in tbe absence of a 'TECH 1' diagnostic tool can the Quad Driver tests be performed using a Digital Volt Meter DVM, or a multi meter, and test light. I have a feeling that most of the components can be tested without the TECH 1 toool? It looks rather abominable but doable with a little more patience.
I don't like giving up. "Once you eliminate the impossible, whatever remains, no matter how improbable, must be the truth." - Sherlock Holmes
#71 | |
Registered Offender
With the older GM ECMs the error codes are stored in memory for the last 50 engine start/run cycles. Once a fault has been repaired, the codes will erase after that occurs.
As for the quad driver outputs in the ECM, they are monitored for open circuits, shorted circuits, and voltages outside the allowable range. Those outputs operate things like the EVAP vent and purge solenoids, TCC lockup solenoid or other transmission shift solenoids, EGR vacuum solenoid, cooling fan relay, A/C clutch relay, and any other options. Shorted or open wiring, disconnected solenoids or relays, or solenoid/relay faults are common problems causing these codes. Your factory wiring diagrams should indicate which loads are connected to QDM A (code 26) and QDM B (code 56).
#72 | ||
In the 200 Club
After I replaced the cam sensor and undid the neg battery terminal overnight, all the codes were erased when I did the first scan but 26 and 56 returned on subsequent scans. I have already checked for continuity on all of the wires from the junction on the inner fender to the PCM. I will have to read back to see what other tests I completed back then. I am preparing myself to go through the whole list of component and circuit tests the best I can with test light and multimeter. Yes, the GM Service Manual does have nice diagrams and text indicating the components controlled by each QDM. I will study that. This could be a nig pie to eat. I need to settle down and go one bite at a time. Thanks again.
#73 | |
In the 200 Club
Re: 1993 TrasSport 3.8L Quad Driver Codes 26 and 56
I noticed something on the road test that could be pretty important here. When I stepped on the gas hard to kick it down, it felt like it didn't develop the power it normally does, then I noticed that the revs were reaching the yellow zone, but I was only doing 100 kph/ 60 mph. Could this indicate a fault with the transaxle Shift A or B Solenoid; or the TCC Apply Solenoid or TCC Brake? It makes sense somehow to me. What exactly do these solenoids do? I have to do some more reading in the manual but this at least might give me a place to start.
How does a guy attach images?
#74 | |
Registered Offender
Images must be hosted (stored) on an external site or web space. Those stored files can be linked into a post using html [img] tags, or by clicking the "Insert Image" icon above the message posting box.
The Following User Says Thank You to Blue Bowtie For This Useful Post: | tinkering (02-19-2022) |
#75 | ||
In the 200 Club
I'd rather spend the time on the TransSport ![]()
