| Latest | 0 Rplys |
Car Modeling Share your passion for car modeling here! Includes sub-forum for "in progress" and "completed" vehicles. |
11-24-2011, 12:14 PM | #16 | |
Re: sanding primer
thanks to all for their input. I did end up sanding to a 3200 grit of tamiya primer layer. waiting to spray it with TS cans. will post some pics. thanks again.
11-24-2011, 12:46 PM | #17 | |
Re: sanding primer
is250 - hope you didn't get to confused with the conflicting replies - each one of us in my opinion has different techniques, skills, equipment, and materials (primer/paint/clear) - so I fully understand the varying opinions you received. Learn from what you have and how you use it and you'll develop your own system - I look forward to seeing some of your work in the near future - John
11-30-2011, 11:11 PM | #18 | ||
Re: sanding primer
12-01-2011, 05:39 AM | #19 | |
Re: sanding primer
is250 - do you use primer for modeling? :mr. hobby or tamiya" primers? They are much better products for using on models than "car" 1:1 spray bomb" can primers, unless you enjoy spending all that time to prepare the primer for paint. If you need to fill large imperfections there is "mr. Hobby" surfacer 500 which fills imperfections, sand and then "1000" or "1200" to use under the paint that requires less preparation. SmokyR67 also makes a good point that is provides an even "color" base for even "color up" build up of color layers. Remember thin layers of the color coat prevent problems like orange peel - checking - crazing etc.so you do not need to sand the paint coats if there are no problems. I'm not a salesman for mr. hobby or tamiya products but they are much easier to use for modeling than 1:1 car primers - and for a beginner will most likely produce a better result. - would like to see pictures of your work added here? - John
12-01-2011, 05:44 PM | #20 | |
Re: sanding primer
Great input here...but mostly if you have an airbrush & access to hobby/model paints...it can be hard to choose a special color online as well as expensive & time consuming to order international just to try out. I'm not against anything said here, just giving a different point of view. I wouldn't use a "filler" primer on a model unless there were special circumstances...
12-01-2011, 09:06 PM | #21 | ||
Re: sanding primer
corvettekid - there are some suppliers for Mr. Hobby primers and clears here in the USA - (Burbank house of hobbies) just google them - there are others and Tamiya stuff (paints/primers) are available at most model hobby stores - Hobbylinc here in the USA is also a good source. As for small amounts of "jar" paints for an airbrush there are some supplies but I like the Zero stuff myself. No mixing thinners with pigments - ready to use and great results. - John |
12-02-2011, 08:20 AM | #22 | |
Re: sanding primer
Thanks! But there aren't any hobby shops near me I also don't use an airbrush. Perhaps I might get one in the future tho. Will these suppliers ship spray cans?
