| Latest | 0 Rplys |
03-25-2005, 12:03 AM | #1 | |
Headlight Problems
I have a 92 Tracker that has no low beam lights, high beam and all other lights are fine. Where do I start?
03-25-2005, 06:05 AM | #2 | |
Re: Headlight Problems
1. Check fuses
2. check bulbs 3. if the simple things check out, then you probably have either a wiring, relay (if the lights are relayed, I don't recall) or switch problem. I'd check the switch with a multimeter to make sure it's making contact on both high and low positions, then work out from there until you find the place where the connection stops.
02 Chevrolet Tracker 4WD |
03-27-2005, 03:17 PM | #3 | |
most likely a headlight bulb.. similar problem just happened on the 96 tracker i bought
"doing that is like trying to sell porn to a 6 year old..... It's just wrong" - hypsi87 LE123456712: i promise i will stop filling your email with my boobs Kieft125: lol.. good, its starting to get rediculous.. |
