Engineering/Technical Ask technical questions about cars. Do you know how a car engine works? |
07-16-2007, 08:48 PM | #1 | |
anyone know anything about vw turbos?
hi everyone, i was given a turbo, brand new, to do with what i please. but i need some information. it has a blue badge labeled kkk and the numbers:
k03-052ED503971 now i could guess and say its from a 99-02 golf/jetta/a3/beetle. looks like this ------> http://www.performance-cafe.com/images/06a145713d.jpg anyway, am i right as far as the car its from? how is the wastegate activated? will i need any of the cars electronics/solonoids to make it work? is there anything i can do to activate the wastegate/set the boost without the stock systems setup? there are 4 oil feeds: two on one side, 1 with a screw on each side and another opposite a hex-head drain plug of some sort. i wanna fabricate a system for an 84 rabbit but i need as much info as i can get on this before i start taking things apart. anything please. |
07-16-2007, 09:24 PM | #2 | |
AF -Advisor
Re: anyone know anything about vw turbos?
K03 is good to 180ish hp. There is an oil feed, and a oil drain. The other two are for coolant, which you can use or ignore if you like.
Not sure why it would matter what car its off of..... Its an internal waste gate. The actuator has a boost reference to it, and can be made adjustable if its not already, or you can add a boost controller for higher boost if you like.
life begins at 10psi of boost Three turbo'd motorcycles and counting. |
07-16-2007, 09:49 PM | #3 | |
hey thanks for the responce. the (vacuum?) line on the wastegate was cut so i have no clue where that connects to. kindof in the dark on this as you can tell. aanyone else have anything i should know about this turbo?
07-17-2007, 09:51 AM | #4 | |
I know that the k03 is a tiny turbo and the wastegate is pre-set but like UncleBob said can be adjusted if you know how to mess with it. I believe this is the same turbo on my wife's 1.8t Passat. Anyway, I do know that it's a reliable turbo if the car it came from wasn't mistreated. What engine are you going to use?
2008 KIA Spectra5 SX 2010 Honda CR-V EX |
07-17-2007, 01:03 PM | #5 | ||
AF -Advisor
Most turbo's put a reference port right on the compressor housing. If the turbo doesn't have one, you could easily add one. Or add one anywhere on the pipe leading to the throttle body I would recommend researching turbo's a lot. They are dangerous in inexperienced hands. Motors go boom very quickly with very small mistakes
07-17-2007, 02:19 PM | #6 | ||
i've definitly learned alot so far. thanks- |
