| Latest | 0 Rplys |
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums. |
06-29-2006, 08:08 PM | #1 | |
92 Cutlass Ciera AC questions
3.3 V6 140,000 miles
A/C clutch doesn't engage, what would cause this? I've never reallly worked with ACs before and the manual only warns me not to do anything until its been discharged. Wires to the AC compressor look fine, where should I start? I was going to buy a recharge kit for it, but it said the AC compressor must be on when i recharge it.. thanks |
07-04-2006, 12:48 PM | #2 | |
Re: 92 Cutlass Ciera AC questions
First, check the fuse and the 12 volts to the A/C clutch relay and clutch coil. If you are low on refrigerant or there is a leak the HVAC system has a pressure switch that detects the charge level. If low or below the threshold the compressor will not cycle. Pressure is checked at the low side port.
If confirmed low, slowly start adding refrigerant until compressor starts cycling. It may take a while so you have to be patient. On some GM models you can jump the pressure switch to get the compressor to turn on and then add refrigeant.
07-04-2006, 01:30 PM | #3 | ||
A990 racer
07-04-2006, 04:25 PM | #4 | ||
The troubleshooting technique is still basically the same. His problem will be getting it recharged if he has a R12 system. Manufacture of R12 may have been stopped but it is still available to licensed AC Techs. I can get R12 right across the border any day of the week. The other possibility is he had a conversion from R12 to R134a already done or plans on using Freeze-12 but we won't know that until he weighs-in and what state he lives in.
07-04-2006, 04:45 PM | #5 | |
A990 racer
Bob, yup on all, but I have not seen to date a 92 GM car with 134, cutoff mandatory was 94 model year I believe, actual production summer 93 of course and yes some Mfg's beat the cutoff , but 92 I don't think so, we'll see.
07-28-2006, 04:20 PM | #6 | |
im not sure how 2 fix it like these guys .. but i can tell u a easy way 2 prevent it from happening agian .. and none of my freinds belive me when i say this ... when u turn off ur car and get out make sure that .. u turn of ur ac as well .. becuase when u turn your car back on .. its bad on ur engine as well as the compressor .. wicth will eventually make it go out sooner than expected ..
07-28-2006, 07:28 PM | #7 | ||
A990 racer
07-28-2006, 10:37 PM | #8 | |
i completely forgot about that. it is rc12. plus theres an ac-line up against a tranny cooling line so its starting to melt. how much would a shop charge for conversion and what needs to be replaced? I live in Massachusetts and they only sell r134a..
07-29-2006, 03:31 PM | #9 | |
A990 racer
Google r134 conversion, tons of info out there, there are cheap conversions that usually don't hold up and there are full line conversions that will work very well, cost $125-1,000!
