| Latest | 0 Rplys |
B-Series/Bravo/Bounty/Drifter Bravo is the Australian vesion, Bounty the New Zealand version and Drifter the South African version. |
11-16-2006, 10:21 AM | #1 | |
2200 prestone trouble
Hi there, I have the opportunity to buy a 1991 B2200 with 140 000 km on it for 800$, only trouble is it's burning prestone, I'm not much of a mechanic (I love to play in the engine, just if I know what the problem is first) so any one of you could tell me what the problem could be? Is it a really pricy repair and how easily could it be done at home?
11-16-2006, 10:43 AM | #2 | ||
Re: 2200 prestone trouble
11-16-2006, 12:14 PM | #3 | |
ok, and how hard is it to change?
11-16-2006, 01:58 PM | #4 | |
Not that difficult. The only problem is when u get it off,since the truck has been burning antifreeze with a blown headgasket,be prepared for nasty surprises when u get head off such as holes burned in top of pistons,burned valves,bad oil rings,warped head ,etc.If u think u can handle what may turn into a full engine rebuild,have at it.If truck runs ok other than burning antifreeze,u may get away with just the head gasket.Biggest headache is getting intake and exhaust manifolds off so u can get head off to replace gasket.Use a copper gasket if u can as they seem to seal better and last longer.BJ
11-16-2006, 03:11 PM | #5 | |
ok, I'll see with one of my friends if he has any place in his garage so that we could work on it together =P
thanks guys! |
11-18-2006, 02:50 PM | #6 | |
B2200 Cylinder Head Inspection and Installation
Make sure you inspect it for warpage before re-installing it. If it it warped more than .003" you are just wasting time and money if you dont' get it straightened and shaved. Also although copper gaskets hold up much better to combustion pressure and are seem to be great on turbocharged engines they are prone to coolant leaks... Make sure you clean all the valves as well, especially the exhaust valves, they will have a hard white build up on them that will cause the valves to overheat and can cause detonation problems.
Owner of Mazdatruckin.com |
Thread Tools | |
