The stock exhaust from the cat back is junk,a stock muffler I had rusted out in under a year.I now use Speedy Muffler King which last 3-4 years.
If you experience your headlights dimming by themselves,replace your headlight switch on the steering column.The copper contacts corrode over time which then make intermittant contact.
If you find that one headlight goes out and the other one goes on high beam for no apparent reason,its your daytime running light control box.Its mounted right beside the battery on the fenderwell.
The stock wheel bolt pattern is 6 X 5.5" and the stock wheel size is 195/75 14 - 5"wide.I went to a 15" rim,2" wider and 205/60 15 tires.What a handling difference
I bought it new and now have just over 325,000km on it with no major probs.I mostly use it for commuting,for speed,I have a Suzuki sportbike
