| Latest | 0 Rplys |
WIP - Street Post topics for any "Works In Progress" street vehicles projects in this sub-forum. |
07-09-2021, 07:29 PM | #301 | |
Re: Lola T-70 Mk III
The driving lights did not align well with the openings in the body. I also thought the openings looked bland being just holes in the nose. I machined two tubes from aluminum impregnated resin and faired them into the nose. This should also help to reinforce the nose where it has been cracking. The inward facing openings of them were shaped to accept the lights.
07-10-2021, 01:29 PM | #302 | |
I wanted to mount the lights to the forward structure for easier final assembly after painting. A new set of mounting brackets were fabbed up and the original light housings were reused.
07-13-2021, 02:15 PM | #303 | |
The seatbelts are complete and ready for installation.
07-14-2021, 04:15 PM | #304 | |
Key switch and water temp, tach and speedo bezels were machined out of aluminum.
07-14-2021, 05:40 PM | #305 | |
Left and right side dash panels. The vents are brass and aluminum with PE screens. Rivets are steel. Glove box door handle and gauge bezels are aluminum; gauge housings are brass.
07-15-2021, 01:29 PM | #306 | |
I made the lenses out of 0.005 sheet styrene and set them in to the bezels from behind. Just a little tedious to fit and secure.
07-15-2021, 03:37 PM | #307 | |
This is the tach "movement" before installation.
07-15-2021, 04:39 PM | #308 | |
These are the finished Auto Meter gauges.
The water temp and oil pressure are mechanical, the tach, fuel level and volts are electrical and the speedo is an electrical GPS unit. |
07-16-2021, 12:45 PM | #309 | |
I made all the switches, more machined aluminum, and got them installed…
I haven't decided if I'll add the labels I made for them yet. |
07-17-2021, 05:00 AM | #310 | |
With the amount of detail you are putting into the build, I would include the labelling
07-18-2021, 02:08 PM | #311 | |
You're correct. I think I will add the labels.
The painted wheels needed one last machining action to remove the paint build up where the aluminum rims mate to them. |
07-18-2021, 03:36 PM | #312 | |
Finished scratch-built wheels with the kit provided tires installed.
The rears have the ends of the axles installed; the front spindles will come later. |
07-20-2021, 08:28 PM | #313 | |
I reworked one of the kit knock-offs and used it as a master and cast four new ones. Tamiya lacquers for the color, aluminum powder for the light shading to enhance the anodized effect.
The rear axle ends are blackened brass and the front spindle ends are machined aluminum. This is the left rear and right front. |
07-20-2021, 08:56 PM | #314 | |
More great progress. I guess this means the main body color is going to be yellow, correct?
07-21-2021, 10:17 AM | #315 | |
No not yellow, it will be the upper color I used on this SMX.
It might get a yellow stripe though. |
Thread Tools | |
